O2 Sensor Question
Old Jun 9, 2006 | 01:49 PM
k9n's Avatar
k9n
Default O2 Sensor Question
I am looking at running no o2 sensor on my car. I have read various opinions about if it would be harmful to the car or not. The car will be tuned using a wideband, but after it is tuned I plan on taking the wideband off and plugging the bung. Then using uberdata, I would disable the o2 sensor which would stop a CEL from being thrown. Would any problems occur?
Old Jun 9, 2006 | 01:56 PM
LVB18Civic's Avatar
Default Re: O2 Sensor Question (k9n)
I've been driving mine without an O2 sensor and have had no problems. My ecu was chipped by phearable.
Old Jun 9, 2006 | 02:35 PM
david@didrace.com's Avatar
You don't need an oxygen sensor once the car is tuned properly. The worst I could see happening is running a slightly different a/f compared to the intended a/f if you're running straight gasoline and then go somewhere where they add like 10% ethanol to the pump.
Old Jun 9, 2006 | 02:58 PM
k9n's Avatar
k9n
okay, sounds good guys, thanks
odishaw
Feb 16, 2008 08:34 AM
urquidezj
Jun 19, 2007 10:16 PM
Inextricabledrvr
Jun 3, 2004 12:53 AM
arjusmc
Oct 23, 2003 04:26 PM
tonylude94
Aug 21, 2003 01:26 PM
