need some help with my 90 da9
i have extremely alot of wear in my ffront tires...is there a way i could change all the wear on the inside of my tires only my front........please help ...tia
Re: need some help with my 90 da9
Wheel alignment, camber is way off, either because alignment is just off or suspension parts, [ball joints, springs, bushings ] are worn out. Your car is a 1/4 century old unless the front end has been done, my guess it is due for a major overhaul .
You can try an alignment, they are not that expensive and the shop will point out any issues you may have with the front end. 94 |
:agree: Get an alignment and have them check for any worn suspension parts.
-Amp |
thanx for your suggestions.....i have a brand new skunk2 camber kit along with skunk2 coilovers same with the back but back is fine.....is there a way to take out the negitive camber on the front??
Originally Posted by freshazfuk
(Post 51067383)
-Amp |
It's more likely that a toe issue is causing the wear than camber.
