HELP!!!!!!!!!!! CHECK ENGINE LIGHT TROUBLE!!! BUT NOT THE USUAL!!!
Hey all, I'm having trouble with my CEL, and the fact that its NOT coming on when the key is on "on".............I am getting no spark, nor do i have an oil pressure light. only a battery light. What is going on here? it is a 94 del sol with an 00 ls motor. what the hell is the problem, i'm dying here because the thing wont fire
Re: (WrongWD)
check ur distributor.
did u do ur own swap or u bought the car with the motor , if u did, in that case the person might have taken out the bulb so it wont go on.
Location: Seattle/Ligonier, WA/PA, United States of Honda
check all your plugs. map tps iacv. check your firing order i did that one time i was like wtf ne ways thats what i would check take one of the spark plug wires out shove a screw drive in it and see if it sparks
Re: (WrongWD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WrongWD »</TD></TR><TR><TD CLASS="quote">already tried that, no spark. firing order is correct, checked the sensors on the intake manifold</TD></TR></TABLE>
have you checked the grounds?
Re: (Archidictus)
if it turns over but there is no spark then it is the igniter module. That went out on my 94 civic, and I had no idea what it was, so I called honda and they told me that it went out on those years alot. They wanted like $220 bucks for it! So i searched on ebay and found a brand new dizzy from distributorking for like $200 with overnight shipping. It also has a 3 year warranty. Just a thought though hope it helps.
usdmEHboy
02-18-2007 07:34 AM
BenB
04-05-2005 09:06 AM
918-Hatch
05-20-2004 09:44 PM
Iamhonda
08-26-2003 08:49 PM
