Need help with Sensor on cat....
Old Nov 23, 2005 | 02:25 PM
escape2me's Avatar
Default Need help with Sensor on cat....
I was trying to install my exhaust but when the bolt came off the exhaust came with it... it pulled out 4 little wires from a sensor on the top of the cat toward the engine side.... What should i do? Can i just re insert them? I had a guy tell me i needed to get a whole new harness and all this ****.... hmmmm.... heres teh pic... [IMG][/IMG]
Old Nov 23, 2005 | 02:30 PM
kchungb17a's Avatar
Default Re: Need help with Sensor on cat.... (97 GSR)
yeah you can just plug the back in the connector, assuming it's not damaged. Just make sure you get them in the right spots on the connector.
Old Nov 23, 2005 | 02:54 PM
escape2me's Avatar
Default Re: Need help with Sensor on cat.... (kchungb17a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kchungb17a &raquo;</TD></TR><TR><TD CLASS="quote">yeah you can just plug the back in the connector, assuming it's not damaged. Just make sure you get them in the right spots on the connector.</TD></TR></TABLE>How do i know if its damaged? And more importantly how do i know where they go? Thanks...
Old Nov 23, 2005 | 08:59 PM
Ls-Turbo's Avatar
lol funny **** .. same thing happend to me id like to know this one
Old Nov 23, 2005 | 09:26 PM
NuclearB18B's Avatar
Default Re: Need help with Sensor on cat.... (Ls-Turbo)
i've done this like 4 times. everytime i forget about the damn sensor and pull the pins out. lol.
anyway, i just plugged the pins in matching them by their wire colors. if you look at the connector from the back with the wires untwisted it's easy to match up to the wires on the other side of the connectors. if you've got two matched up in a square, (green to green, white to white) the black wire coming out of the sensor next to the green wire gets plugged in next to the green wire on the connector. i hope that makes sense.
Old Nov 24, 2005 | 09:55 AM
escape2me's Avatar
Default Re: Need help with Sensor on cat.... (NuclearB18B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NuclearB18B &raquo;</TD></TR><TR><TD CLASS="quote">i've done this like 4 times. everytime i forget about the damn sensor and pull the pins out. lol.
anyway, i just plugged the pins in matching them by their wire colors. if you look at the connector from the back with the wires untwisted it's easy to match up to the wires on the other side of the connectors. if you've got two matched up in a square, (green to green, white to white) the black wire coming out of the sensor next to the green wire gets plugged in next to the green wire on the connector. i hope that makes sense.</TD></TR></TABLE>Ummm hahaha, i was more confused than when i got high for the first time and my brother and his friend told me i just smoked dried banana peels and nutmeg... But thanks, i got a knowledgable guy to help so
Old Nov 24, 2005 | 12:39 PM
raffiT78's Avatar
lol, was gonna explain but if you already managed to figure it out then your good to go.
Old Nov 24, 2005 | 06:30 PM
Liquid Ice NF's Avatar
haha, glad i'm not the only one who does this.
Manlion
Feb 23, 2010 12:12 PM
paniaguae640
Jul 30, 2008 04:24 PM
BLUE EH3
14
Jun 19, 2005 10:16 PM
drunknbass
Dec 24, 2003 10:02 PM
[HrZn]4life
May 20, 2003 03:57 PM
