differences in intake manifolds, LS
Old Nov 24, 2005 | 05:44 PM
civicdust's Avatar
Default differences in intake manifolds, LS
whats the difference from the obd1 and the obd 2?
are there extra sensors and stuff? reason i ask is because i dropped a obd1 swap into mine, and i dontknow if all the plugs are the same
Old Nov 24, 2005 | 06:33 PM
LordAphotic's Avatar
there arent extra sensors. only thing is that the electronics that bolt on to it are designed to work with either obd1 or obd2 i believe.
like the IACV and other electronic things. you can just swap over you current obd2 things on to it and they should bolt on. im not sure about the gsr intake manifold though cause i havent had a chance to disect that one yet.
LSteggyguy
Dec 24, 2019 12:47 PM
teggything
Jan 16, 2009 11:08 PM
go2sleep
Nov 3, 2005 05:15 PM
integranator
Dec 21, 2002 07:16 PM
