Need help quick
Old May 2, 2003 | 02:42 AM
Toda Built's Avatar
Default Need help quick
For those of you with systems...where did you run the power wire through the fire wall? Did you have to drill or is there a hole that you can slide the wire through?
Old May 2, 2003 | 02:51 AM
10K2HVN's Avatar
Default Re: Need help quick (SH_LUDER)
There is hole where stock wires are ran through but you could drill your own hole..just make sure its sealed...
Also, this is in the wrong forum, should be in Audio/Alarm....
Old May 2, 2003 | 03:08 AM
Toda Built's Avatar
Default Re: Need help quick (10K2HVN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 10K2HVN &raquo;</TD></TR><TR><TD CLASS="quote">There is hole where stock wires are ran through but you could drill your own hole..just make sure its sealed...
Also, this is in the wrong forum, should be in Audio/Alarm....</TD></TR></TABLE>
Which hole? do you have a picture? Sorry about this being in the wrong forum but the audio and security forum moves to slow and I need answers now.
Old May 2, 2003 | 03:18 AM
10K2HVN's Avatar
well its not just a hole (well i havent installed a system in my teg yet and i havent done any systems in a long time) but should be on the passenger side near the battery, youll see a bulk of wires going through the fire wall its typed to a rubber boot to keep it sealed. the easy way to do it is to just poke a hole with a screwdriver the push the wire through and find it on the other end under the dash...
jeff652
Audio / Security / Video
Jan 1, 2011 12:00 PM
tambara
19
Feb 19, 2007 08:21 PM
FF-sean
Jul 20, 2003 06:00 PM
boszyen
Jun 13, 2003 06:54 AM
axnpacked
Oct 21, 2002 12:49 AM
