Need Help!! ASAP
Old Dec 2, 2006 | 08:57 AM
SlammedBlackGSR's Avatar
Default Need Help!! ASAP
I finally got the code for the check engine light last night and it says i need a Knock Sensor....The check engine light doesnt come on right when i turn the car on, it will come on about 10 minutes laters when im driving......what i want to no is, is the knock sensor expensive? and where is it located? is it hard to install?..........i have a 95 integra GSR..........my buddy told me it was in back of the block?.........thank you for your time
Old Dec 2, 2006 | 09:14 AM
jthm's Avatar
Yes its expensive, its right above the oil filter. A plus, any honda knock sensor will work, try and get one from ebay or a junk yard. I see a few on ebay right now.
Old Dec 2, 2006 | 09:19 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Need Help!! ASAP (SlammedBlackGSR)
It is a pain to change. This link will help you to plan a little:
https://honda-tech.com/zerothread?id=1619832
Old Dec 2, 2006 | 10:20 AM
99Geeezer's Avatar
they are kind of a pain with a stock intake manifold. it's not so bad if you have a skunk or blox manifold. you might need to drain your coolant a little bit. i just changed mine about two months ago. and yes they are expensive.
ddbraungart
Honda CR-V & Element
Feb 24, 2018 08:34 AM
TheCirclingSky
Apr 13, 2010 08:19 PM
lv6l
Jan 2, 2005 05:55 PM
StewdaddySiRII
Oct 17, 2004 06:58 AM
Stefndogg
Aug 1, 2004 01:47 AM
