My Clogged cat ?
Old 01-26-2007, 12:49 PM
.Thomas's Avatar
Default My Clogged cat ?
If i take out all the inside stuff of the cat, and put back in the o2 sensor, will i throw a code?
this is in a 96 RS.
I am doing this because all the stuff fell off the walls of the cat, not to be super fast with my CAI.
or is there a spacer thing i can buy?
Old 01-26-2007, 01:45 PM
Kr4nG's Avatar
you wont throw any codes. ive done this almost 2 times. 1 was with my bros accord. he didnt want to spend money on a high flow cat. so we drilled and took all the honey combs out of the cat. car worked perfect. and right now i dont even have a cat. just a pipe. that acts as a cat. but my o2 sensor isnt on the cat its on my headers. but accord we did it no engine light. you mean your cat was making noise? and when you unscrew it all the dust fell out? make sure you took everything out so it looks like a empty pipe. or it will keep falling and make noise.
Old 01-26-2007, 02:07 PM
SmogKing's Avatar
Default Re: My Clogged cat ? (TanCar)
your car is a OBDII vehicle, so it will throw a code
Old 01-26-2007, 02:38 PM
4drgsr96's Avatar
Default Re: My Clogged cat ? (SmoGuy)
if your throw any code it would be
catalyst efficiency below threshold
Old 01-26-2007, 02:58 PM
.Thomas's Avatar
Default Re: My Clogged cat ? (96civb18c1)
i am throwing a code ...
what do i do to get rid of it besides of buying a new cat?
Old 01-26-2007, 03:58 PM
4drgsr96's Avatar
erase it. i didnt have money to buy a new cat when i had my almighty d16y7, but my cat was clogged and a mechanic just hollowed it out. it would throw the "efficiency" code and i would just erase it.
what can i say? i had no money.
Old 01-26-2007, 05:07 PM
.Thomas's Avatar
how do you erase it?
oh and no worries, im in the same boat as you with no cash.
Old 01-26-2007, 05:45 PM
NY state of mind's Avatar
pull the ECU FUSE for a little while ( more then ten seconds ) or disconnect the negative battery cable but with this you will lose all memeory stored on your radio. then plug it back in and expect to see the code again, after that go out and buy a new converter. then once that is installed try clearing the code again.
Modified by NY state of mind at 12:06 AM 1/27/2007
Old 01-27-2007, 08:09 AM
4drgsr96's Avatar
Default Re: My Clogged cat ? (NY state of mind)
or you can go at any autozone or kragen and borrow a code scanner and jsut erase it, after awhile mine stopped coming on for that code.
Old 01-27-2007, 08:47 AM
Stein's Avatar
New cats are like $100...
Old 01-27-2007, 09:10 AM
4drgsr96's Avatar
Default Re: My Clogged cat ? (Stein)
for an obd1 yes around that obd2 universals are about 150 or so, but that doesnt mean theyre california certified, which is where i'm at. CA cert. cats are about 250. OEM cats brand new are about 700
elpiar
05-08-2005 09:37 AM
Krut
01-08-2005 10:39 PM
Two_K Si
10-13-2004 08:32 PM
silver ek
02-09-2004 10:05 PM
maxxdout
06-24-2002 07:40 PM
Quick Reply: My Clogged cat ?
