ABS Light!
Old Apr 21, 2006 | 02:44 PM
AJ21GSR's Avatar
Default ABS Light!
My 95 GSR has the ABS light coming on every time I drive. When I first start the car it's not on, but sure enough after a few minutes it turns on. If I cut the engine and start it again it does the same thing. Off for a few minutes, than on again.
Any ideas?
Old Apr 21, 2006 | 02:51 PM
92integra-R's Avatar
Default Re: ABS Light! (AJ21GSR)
sorry, ma **** is to old to have abs! good-luck
Old Apr 21, 2006 | 02:54 PM
Lan's Avatar
Lan
It is probably a wheel sensor, check the code yet?
Old Apr 21, 2006 | 02:57 PM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default Re: ABS Light! (Lan)
not trying to be a dick, but you can learn alot by searching, this topic is covered daily and theres plenty of good threads, even including all the ABS codes
Old Apr 21, 2006 | 02:58 PM
Lan's Avatar
Lan
Default Re: ABS Light! (BOLO-FTW!!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOLO-FTW!! &raquo;</TD></TR><TR><TD CLASS="quote">
not trying to be a dick, but you can learn alot by searching, this topic is covered daily and theres plenty of good threads, even including all the ABS codes</TD></TR></TABLE>
You are such a jerk!
Old Apr 21, 2006 | 03:24 PM
Guess whos bizzack
seriously though, that button works miracles
Old Apr 21, 2006 | 03:49 PM
Lan's Avatar
Lan
oNLY KIDDING DUDE
Old Apr 21, 2006 | 04:51 PM
Lan's Avatar
Lan
You should apologize to the OP bolo
Old Apr 21, 2006 | 05:14 PM
Guess whos bizzack
Por Que?
Old Apr 21, 2006 | 06:05 PM
Lan's Avatar
Lan
Only kidding dude geesh... you don't have to get all bilingual on me
Old Apr 21, 2006 | 06:21 PM
Guess whos bizzack
sorry theres a mexican here while im drunk so i have to talk it holla11
Old Apr 23, 2006 | 03:52 PM
AJ21GSR's Avatar
No, I haven't checked the code yet...
To be honest, I don't have something to check the codes.
I'm not even really sure where to start on this one.
Sorry I didn't use the search, but in the future, I will try and make sure I utilize that function.
Thanks
Old Apr 23, 2006 | 03:56 PM
NA JDM GSR's Avatar
wut does the ABS light look like????
Old Apr 23, 2006 | 04:37 PM
DC2 Mang's Avatar
the front ABS sensors are probably dirty, there is a thread on how to clean them on here
Old Apr 23, 2006 | 05:13 PM
-Todd-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AJ21GSR &raquo;</TD></TR><TR><TD CLASS="quote">To be honest, I don't have something to check the codes.
Do you know how to check the cel? You check the abs and srs codes the same way. Look in the FAQ at the top of the integra forum.
Old Apr 23, 2006 | 07:51 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
https://honda-tech.com/zerothread/1584925
here u go
Old Apr 23, 2006 | 07:52 PM
DC1212's Avatar
same things happened with my 94, look up the cleaning it worked for me.
jordan_civic
Aug 31, 2007 07:36 PM
Type_R_Lover
Nov 7, 2006 09:10 AM
310HPS2k
Sep 25, 2005 06:09 AM
extracrunchie
Oct 19, 2004 08:21 AM
nwdrifter
Sep 29, 2004 07:31 AM
