Engine light on
Old Nov 26, 2004 | 07:41 AM
sweetride's Avatar
Default Engine light on
My engine light just came on last nite on my 98 gsr. Is there some way to find out what is making it come on? How do you read what code it is ?
Old Nov 26, 2004 | 08:12 AM
sabotage7's Avatar
Default Re: Engine light on (sweetride)
read this!....its at the very beginning of this forum btw!
Old Nov 26, 2004 | 08:38 AM
HONDA RR's Avatar
Default Re: Engine light on (sabotage7)
YOU NEED TO REMOVE THE SERVICE CONNECTOR WHICH IS LOCATED UNDER THE PASSENDER SIDE DASH NEAR THE ECU. YOU NEED TO TAKE THE CONNECTOR AND JUMP IT WITH A PAPER CLIP OR ANY OTHER WIRE. ONCE YOU HAVE CONNECTED THE WIRE TO BOTH PINS ON THE CONNECTOR TURN YOU IGNITION KEY ON AND YOU WILL NOTICE THE ENGINE LIGHT BLINKING COUNT THE BLINKS. THESE BLINKS WILL REPEAT OVER AND OVER WITH A SHORT BREAK BETWEEEN EACH CODE. COUNT YOUR BLINKS AND COMPARE IT TO THE BIGINNING PART OF THIS FORUM WHICH HAS A SECTION ON CHECK ENGINE LIGHT CODES. IF YOUR ARE CONFUSED WITH WHAT I'AM TRYING TO SAY, JUST BUY THE HAYES MANUEL ITS TELLS YOU EVERYTHING.
Old Nov 26, 2004 | 08:41 AM
Convoy's Avatar
Default Re: Engine light on (MITSUBA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MITSUBA &raquo;</TD></TR><TR><TD CLASS="quote">YOU NEED TO REMOVE THE SERVICE CONNECTOR WHICH IS LOCATED UNDER THE PASSENDER SIDE DASH NEAR THE ECU. YOU NEED TO TAKE THE CONNECTOR AND JUMP IT WITH A PAPER CLIP OR ANY OTHER WIRE. ONCE YOU HAVE CONNECTED THE WIRE TO BOTH PINS ON THE CONNECTOR TURN YOU IGNITION KEY ON AND YOU WILL NOTICE THE ENGINE LIGHT BLINKING COUNT THE BLINKS. THESE BLINKS WILL REPEAT OVER AND OVER WITH A SHORT BREAK BETWEEEN EACH CODE. COUNT YOUR BLINKS AND COMPARE IT TO THE BIGINNING PART OF THIS FORUM WHICH HAS A SECTION ON CHECK ENGINE LIGHT CODES. IF YOUR ARE CONFUSED WITH WHAT I'AM TRYING TO SAY, JUST BUY THE HAYES MANUEL ITS TELLS YOU EVERYTHING. </TD></TR></TABLE>
You need to remove the CAP LOCK!!!!!!!
the.hamburglar
May 6, 2007 09:37 AM
ITR624
Feb 27, 2003 09:25 PM
katie
Dec 9, 2002 06:44 PM
350z-tech
Nov 7, 2001 04:19 PM
