LSD Question
Old May 24, 2014 | 10:02 PM
CKnight90's Avatar
Default LSD Question
So this has been bothering for the past few days since i changed my oil
I had my front end of car on jack stands. I was wondering if i had lsd. I've had the car over a year now and haven't really cared to find out til the day i had it on jack stands. I put my car in 1st gear. Put a small pole to rev the engine to 2400rpm. Looked at my tires. Noticed only my driver side wheel spins fast, while my passenger side wheel struggles to spin. Passenger wheel kind does a jerking motion to rotate. I tried to assist it by spinning it by hand but doesn't help it. Just keeps jerking and moves an inch at a time.
Is there something wrong with my trans? bad part somewhere?
thanks for reading!
Old May 24, 2014 | 10:28 PM
Black R's Avatar
25 Year Member
Default Re: LSD Question
You can do this at idle - just try to hold the passenger side wheel.
It will try to spin the drivers side wheel if you have LSD.
It's pretty easy to remove the axle and look inside the hole to see if you have LSD though.
Just do that.
Old May 24, 2014 | 10:51 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
What trans do you have? That's an easy way to tell if you have a LSD.
Torsen/worm gear LSD's are open diffs if one wheel is in the air with 0 grip. They work on torque multiplication. And 0 x (anything) = 0. That's the short and dirty explanation. But you can read all about torsen/helical/worm gear LSD's for my explanation to make sense.
1. What trans do you have?
2. Remove the passenger side axle and look thru the diff hole.
Old Jun 2, 2014 | 10:55 PM
CKnight90's Avatar
Jacked up car. Turned driver side and Passenger side wide wheel spins in opposite direction. Turn Passenger side wheel and driver side wheel spins in opposite direction. LSD?
Old Jun 3, 2014 | 01:29 AM
m4xwellmurd3r's Avatar
No lsd
Old Jun 3, 2014 | 04:09 AM
B serious's Avatar
:facepalm:
What trans is it? GSR? ITR? B16? USDM? JDM?
Old Jun 3, 2014 | 06:43 AM
fcm's Avatar
fcm
Old Fart
If you turn one wheel and the other turns in the opposite direction, you do not have LSD, if turning one wheel turns the other in the same direction, you have LSD. 94
Old Jun 3, 2014 | 10:19 AM
CKnight90's Avatar
vin says gsr and a sticker says s80
Old Jun 3, 2014 | 03:02 PM
B serious's Avatar
So it's a USDM GSR trans. Those did not come with a LSD. JDM GSR (SIR-G) transmissions did come with an LSD option....but they don't have VIN numbers. They had viscous LSD's which don't behave like the torsen/helicals in the ITR/CTR trans.
When you say VIN says GSR, what 2 numbers come after the "JH4DC2"? Or does it read JH4DB8?
jdmsleeper12
Transmission & Drivetrain
13
Jan 21, 2010 04:58 PM
Rolo30
Apr 29, 2009 04:15 PM
1Quikgsr
Feb 12, 2004 08:11 PM
comptechgsr
Jan 24, 2003 05:14 PM
TypeR 599
Aug 26, 2002 02:10 PM
