LsD problem
Old Feb 12, 2004 | 04:53 AM
1Quikgsr's Avatar
Default LsD problem
when i ordered my motor i had not specified that i wanted lsd or not... so my motor comes and to find out i have lsd. So about 2 months before my car was ay performance muffler shop and my friend says spin your right wheel so i did and the passesnger spun the opposite direction. Now i was doin my oil and was ****** around with it and spun the wheel and nothing happened, is my lsd fucked up please someone help.
Old Feb 12, 2004 | 05:02 AM
rapid_roy's Avatar
Default Re: LsD problem (1Quikgsr)
LSD's just don't stop working. They break. If you broke it, you would know without a doubt.
Also, I am pretty sure that the car needs to be in gear if you spin the wheel. Not sure though, someone correct me if I am wrong here.
Cheers,
Sean
Old Feb 12, 2004 | 05:21 AM
m R g S r's Avatar
Default Re: LsD problem (rapid_roy)
I have a stock open diff. and when my car is jacked up and I spin one wheel, the other wheel spins the opposite way.
Old Feb 12, 2004 | 08:31 AM
blacksheep's Avatar
doesn't sound like you have LSD?
Old Feb 12, 2004 | 08:51 AM
Sliced Beard's Avatar
Default Re: LsD problem (blacksheep)
put the car in gear and spin the wheel while the car os off of the ground
you may have to take the spark plugs out to make th spinning easier
but when you spin one wheel while it is in gear the other should spin the same direction also
Old Feb 12, 2004 | 09:17 AM
NeoGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1Quikgsr &raquo;</TD></TR><TR><TD CLASS="quote">when i ordered my motor i had not specified that i wanted lsd or not... so my motor comes and to find out i have lsd. So about 2 months before my car was ay performance muffler shop and my friend says spin your right wheel so i did and the passesnger spun the opposite direction. Now i was doin my oil and was ****** around with it and spun the wheel and nothing happened, is my lsd fucked up please someone help. </TD></TR></TABLE>
your motor doesn't have LSD, the tranny does....if you pull the axles, look through the tranny, if you see a bar blocking the other side, it's not a LSD, if you can see straight through, it's LSD equipped
Old Feb 12, 2004 | 04:45 PM
1Quikgsr's Avatar
dumb me i had it in neutral thanks for the heads up guys.
Old Feb 12, 2004 | 08:08 PM
darrinbrewer's Avatar
Default Re: LsD problem (NeoGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NeoGSR &raquo;</TD></TR><TR><TD CLASS="quote">
look through the tranny, if you see a bar blocking the other side, it's not a LSD, if you can see straight through, it's LSD equipped</TD></TR></TABLE>
Old Feb 12, 2004 | 08:11 PM
Kendall's Avatar
Due to the design of a helical geared limited slip differential (the kind Honda uses). Free spinning one wheel (not in gear) will cause the opposite wheel to rotate in the opposite direction. Please search for more details as this has been covered many times in the past.
jdmsleeper12
Transmission & Drivetrain
13
Jan 21, 2010 04:58 PM
comptechgsr
Jan 24, 2003 05:14 PM
TypeR 599
Aug 26, 2002 02:10 PM
celica73
33
Aug 21, 2002 10:33 AM
Soku1kcivic
Apr 16, 2002 04:21 PM
