Ls-Vtec info
Old Jan 15, 2006 | 08:54 PM
Integacivic's Avatar
Default Ls-Vtec b16 head and tranny info STOCK
ok im planning on taking my b18b1 block and using a b16 head and tranny. norm task. But what I dont know is what the numbers I might be putting down for hp, or 1/4 mile.(I have looked around and seen from 180hp like inbetween gs-r and type-r)I know every engine is diffrent and not the same but if you know, or have a <U>stock</U> ls-vtec b16 head and tranny and have the info please share. Thanks.
Modified by Integacivic at 10:05 PM 1/15/2006
Modified by Integacivic at 10:06 PM 1/15/2006
Old Jan 15, 2006 | 09:02 PM
LSvtec03's Avatar
Default Re: Ls-Vtec info (Integacivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integacivic &raquo;</TD></TR><TR><TD CLASS="quote">I know every engine is diffrent and not the same </TD></TR></TABLE>
then you know this is a bunk question that depends not only on the slight differences of the engine, but what kind of set up each person is using. someone using a stock ls bottom and stock gsr top is going to have totally different numbers than someone with 12:1 pistons and wild cams or the low compression turbo....and we wont even go into those great lengths....
Old Jan 15, 2006 | 09:04 PM
Default Re: Ls-Vtec info (LSvtec03)
right right my bad I mean stock b16 head and tranny thanks for the insight
Old Jan 15, 2006 | 09:09 PM
highmilehatch's Avatar
The only way to answer your question is to build it, tune it, get out there and drive it. See what you and your car is capable of. Tires and your driving ability will be the result.
Old Jan 15, 2006 | 10:29 PM
Spectrum24x's Avatar
Default Re: Ls-Vtec info (highmilehatch)
stock block, stock b16 head, i'd say your gonna make somewhere in the ranges of 140-160hp least to the most.
My block is fully built and tuned and im making 186whp.
My friend did a stock b20 bottom end with stock b16 head and made 165; but the b20 is a bit stronger then the ls.
But as stated before, every motor is different, but your not gonna make 180 on stock block, stock head.
Old Jan 16, 2006 | 08:07 AM
scottishdave's Avatar
Default Re: Ls-Vtec info (Spectrum24x)
Build it and find out, I have a stock block ls with a stock b16head. shitty header, short intake and 2.5 exhaust with gsr cat and apexi n1. i can run 15.2 sometimes, then again my clutch may not be in the best shape and even more important my driving skills may not be in the best shape either.
Old Jan 16, 2006 | 08:47 AM
ernald711's Avatar
Default Re: Ls-Vtec info (scottishdave)
stock b16 head. semi built bottom with jdm itr .25's. making 175whp. sacraficed a little power for reliablility. no track times.
Old Jan 16, 2006 | 09:43 AM
TheNosR's Avatar
Default Re: Ls-Vtec info (ernald711)
its basically going to be like a gsr and youll probably get a lot of info if you search on it alot
Old Jan 19, 2006 | 10:18 PM
Default Re: Ls-Vtec info (h22special)
thanks for the info guys, Ill post what I end up with.
Old Jan 26, 2006 | 05:22 PM
Elbowpunk's Avatar
is this conversion hard to do ?? u think a 16 year old can do it out of the house or do u need all that fancy **** to help with the process?? and has anyone actually done this themsleves to name all the parts involved .. thanks !! lookin to do this myslef and i got all money to do it
Old Jan 26, 2006 | 07:30 PM
LSvtec03's Avatar
Default Re: Ls-Vtec info (Elbowpunk)
lol! that depends....on how much experience you have and what you consider to be "fancy ****." if you know what you're doing, no, it's not difficult.
Old Jan 27, 2006 | 05:26 PM
ernald711's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elbowpunk &raquo;</TD></TR><TR><TD CLASS="quote">is this conversion hard to do ?? u think a 16 year old can do it out of the house or do u need all that fancy **** to help with the process?? and has anyone actually done this themsleves to name all the parts involved .. thanks !! lookin to do this myslef and i got all money to do it </TD></TR></TABLE>
i wouldn't advise doing this swap until you've got some basic experience on minor things like changing out a head gasket and doing valve lashing.
Old Feb 3, 2006 | 07:05 AM
Civicracer17's Avatar
so how do you do this conversion?
Old Feb 10, 2006 | 08:38 PM
ernald711's Avatar
Default Re: Ls-Vtec info (Civicracer17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicracer17 &raquo;</TD></TR><TR><TD CLASS="quote">so how do you do this conversion?</TD></TR></TABLE>
are you try'n to be funny?
Old Feb 11, 2006 | 04:12 PM
Elbowpunk's Avatar
Well about a
1/2 cup reading information
1/4 cup having money
1/4 cup knowledge
^^ put it all together ... and BAM you got urslef a Ls / Vtec engine !
Old Feb 11, 2006 | 05:20 PM
tegG2's Avatar
Does anyone ever do their research on LS/vtakk????? Read up, then make a decision, just dont do it b/c it sounds cool and give you unreliable horsepower.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicracer17 &raquo;</TD></TR><TR><TD CLASS="quote">so how do you do this conversion?</TD></TR></TABLE>
Old Feb 11, 2006 | 05:37 PM
LSvtec03's Avatar
Default Re: Ls-Vtec info (tegG2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegG2 &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone ever do their research on LS/vtakk????? Read up, then make a decision, just dont do it b/c it sounds cool and give you unreliable horsepower.
...</TD></TR></TABLE>
you obviously have some homework to do of your own.
Old Feb 12, 2006 | 07:41 AM
Vtecme92's Avatar
I have a stock gsr head on LS block with a si tranny best time at the track 14.9..I/H/E/
Old Feb 12, 2006 | 08:30 AM
mac_24_seven's Avatar
Default Re: Ls-Vtec info (Vtecme92)
I just posted a HUGE FAQ on LS/Vtec just last week.
My god pple, just SEARCH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!! Search!!
monzster
Aug 23, 2008 10:09 PM
jdmcivic1
Oct 25, 2007 06:09 AM
wechill187
Nov 16, 2006 01:18 PM
hb_rule_b18
Aug 22, 2005 03:48 PM
hondanut101
May 18, 2005 02:58 PM
