LS/Vtec gasket question
Im building a LS vtec b16 head b18b block.
stock springs retainers cams etc...
ARP rod bolts etc.. either p30 or 73 pistons oem bearings. stock rods/crank
I want to replace all of the gaskets that are needed/recommended.. does anyone have a list? I've been searching most of the ls/vtec threads give a general "replace the other gaskets" which is too vague.. I wanna make a big order of them this way I can save on shipping/trips down to my parcel service...
Also, will a b20 oil pump be suffice for a LS/vtec build? or should I get a vtec/keep my b18 pump?
thanks
thanks
Re: LS/Vtec gasket question
if i remember right, any b series motor after 95 all have the same oil pump. so your b20 oil pump should have the same part number as a ITR oil pump.
D-meet07
09-14-2005 02:56 AM
