car wont start all the sudden
Old Jul 13, 2004 | 12:13 PM
krack's Avatar
Default car wont turn over all the sudden
car wont turn over all of the sudden...
i drive a 90 teg and the past 2 fridays after work i go out to start my car and the dam thing wont turn over,, its allmost like its not getting gas cause i look at my fuel pressure gauge and it reads 0 , but why would it only due it some times. and by the way is that my fuel pump under my back seat?
cool thanks again for any help...
Modified by KRIZACK at 1:59 PM 7/13/2004
Old Jul 14, 2004 | 08:59 PM
bens_redeg's Avatar
Default Re: car wont turn over all the sudden (KRIZACK)
dont know why your not starting but yes that is your fuel pump under your seat
Old Jul 14, 2004 | 09:31 PM
sticks5141's Avatar
Check your main fuel relay had the same problem on my 93 teg. If you can get to see you can see the fuel relay you should hear it click when you turn the key on if not trying taping it with a screw driver a few times and try some more. If still nothing buy a new one
Old Jul 18, 2004 | 10:08 AM
bens_redeg's Avatar
Default Re: car wont turn over all the sudden (sticks5141)
yeah turn the key over but not to starting position and youll hear the fuel pump humm for like 5 seconds that means your fuel pump is ok. check all grounds fuses, main relay, distributor components(cap, rotor, coil, ignition control module) plugs and wires check your battery and your starter also
Old Jul 18, 2004 | 10:09 AM
bens_redeg's Avatar
Default Re: car wont turn over all the sudden (bens_redeg)
oh and check your timing also
Old Jul 18, 2004 | 10:17 AM
Vardoulika's Avatar
Ok thing is on a G2 teg the fuel pump is not directly under the seat, that silver circle thing is where all the wiring and relays are but to access the fuel pump on a G2 you have to actually drop your fuel tank its in the back drivers side corner.
Old Jul 18, 2004 | 11:35 AM
civicbro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sticks5141 &raquo;</TD></TR><TR><TD CLASS="quote">Check your main fuel relay had the same problem on my 93 teg. If you can get to see you can see the fuel relay you should hear it click when you turn the key on if not trying taping it with a screw driver a few times and try some more. If still nothing buy a new one</TD></TR></TABLE>
He's right! It's the relay, I had the exact same problem
MY934dr
May 28, 2013 12:50 PM
Champs32
15
Aug 30, 2010 02:17 PM
allmotor2.1
Nov 24, 2007 04:52 AM
91d15bvtec
Jun 29, 2005 05:08 PM
TodaSi
Aug 2, 2002 05:06 PM
