Converting from LS-Turbo to LS/VTEC Turbo, confused on a few aspects...timing belt...
with a vtec head on a LS block with a LS water pump and LS oil pump, do i still use a LS timing belt or a VTEC timing belt (if they are different) because a vtec head is taller which might require the longer timing belt.
thANks!
i guess to do the swap, i must get the golden eagle dowels for the head, lsvtec oil line kit, p28 ecu socketed for hondata and a LS headgasket plus the 2 vtec wires to run.
thANks!
Re: Converting from LS-Turbo to LS/VTEC Turbo, confused on a few aspects...timing belt... (wade)
the wiring part is good. i beleive i never did an ls swap.
but their must be a lot of info on the HT site
Calvin
Calvin
from what ive heard, if you use the ls water pump, ls timing belt. if you use a gsr/itr water pump, then a gsr/itr timing belt.
you use the timing belt that belongs with the water pump, it dosent matter with oil pumps but i would use a vtec one i recomend a 94 gsr one, so for example if you have a ls water pump you use a ls timing belt and vise versa
Re: Converting from LS-Turbo to LS/VTEC Turbo, confused on a few aspects...timing belt... (rondigs)
thanks! looks like wit a LS water pump i need LS t-belt. i will continue to use my newer LS oil pump. thats alot of work to do a oil pump.
rondigs, even wit a LS block and B16 head... i need the GSR head studs? arnt all vtec head studs the same?
i got all the parts for an LS vtec setup hit me
up
i even got pistons and rods
arp headstuds
hondata gasket
lsvtec kit
itr water pump, oil pump, timing belt
all brand new
up
arp headstuds
hondata gasket
lsvtec kit
all brand new
Re: Converting from LS-Turbo to LS/VTEC Turbo, confused on a few aspects...timing belt... (AznInvasi
AZN, r they GSR head studs? if so, how much? how much for the hondata gasket? is the gasket for b16 heads itr gsr heads?
turbo_b16_ex
10-04-2005 11:06 AM
