ls vtec?!?!?1
Old May 26, 2007 | 05:53 PM
ls_bitik's Avatar
Default ls vtec?!?!?1
how much power should a ls vtec have.????? jdm 16 sir and b18a bottom?? pretty much stock everything...
Old May 26, 2007 | 05:58 PM
tomlinson619's Avatar
Default Re: ls vtec?!?!?1 (ls_bitik)
pretty lame question.. every motor is different. put it on a dyno if u want the real answer.. but if u say just a complete stock block on a complete stock head, id say maybe anywhere from 120-150 whp
Old May 26, 2007 | 06:04 PM
ls_bitik's Avatar
Default Re: ls vtec?!?!?1 (tomlinson619)
thanksss i just want to know whats the power range of it... ill probably get the cams and camgears next.. but if im geting the stage 2 i need to change the valve spring and retainners right?! i jsut want to hit around 180 to 200 whp....
Old May 26, 2007 | 08:41 PM
no.. invest in some high compression pistons first. an LS VTEC NEEDS pistons to be successful. look into some ITR or b16 pistons.. a stock block LS has low compression and with big cams, ur still probably slow. my friend made almost 200 whp with b16 pistons in his LSVTEC with skunk stage2 cams. and yes upgraded valvetrain is required. hope this helps.
Old May 27, 2007 | 11:56 AM
doood's Avatar
been there done that
you need tons more research if you ever hope to come near 200whp
yaucovtec
Mar 4, 2009 09:54 AM
the_big_dl86
11
Feb 13, 2008 11:54 AM
KAWZ92DA
Oct 19, 2006 09:42 PM
blwn95civic
Oct 12, 2006 01:39 AM
Dj Lotte
Dec 15, 2003 10:43 AM
