Ls V-Tec Build
Ls V-Tec Build
i have a 96 integra ls.. my buddy just gave me a vtec head im kinda new at this but i wanna know what all do i need to make this ls block i have and official ls vtec. now i have cams for it and the head, besides the ecu (which i'm on the prowl for a p72 obd1) what else would i need?
Re: Ls V-Tec Build
if you have all the parts it's not too hard to pull off. if you plan to use the p72 ecu i assume you have a p72 head and the gsr intake manifold? if you use a single runner on the p72 it will need a fpr and wideband to get the af right. search this forum and all motor for some good detailed write ups.
i normally hate lsvtec for more than a few reasons, but, in your case, why not? you have all the parts, build it on up
Re: Ls V-Tec Build
yeah im with you bro. i have a b18a with 152k and all my friends are mechanic but theyre too lazy to help me out ha! so ima subscribe and hit me up with what your plans are!
92 DA
92 DA
Re: Ls V-Tec Build
yea man go for it, i gotta 00 si im in the process of doin this , i jus plugged the bottom of the head (oil passage) today, and now jus waitin for the block to come back from the machine shop to assemble this monster good luck bro!!!!
Re: Ls V-Tec Build
Isn't it already VTEC?...or are you swapping a B18B1 in it, and making it LS-VTEC? If you're doing a swap, I would just get a GSR motor...most people do LS-VTEC to save on money, because they claim it's cheaper than swapping a GSR motor, but it sounds like you're doing a whole swap anyway, so why not just put another B16 in it, or a B18C1? I'm against LS-VTEC too...
Re: Ls V-Tec Build
i build my lsvtec lst year. runs great, i love it. spend some money, get a good complete lsctec kit that includes lines, adaptes headgasket ect. make sure you get the correct head bolts. use a new gsr timing belt and water pump. if you have the monet get the head decked/machined. if not you risk runing you new head gasket. the first few days check for oil leaks. i had to pull my cams out to repalce all the cam seals cuz they where squirting oil. take ur time, do it right
om me if you want to buy a chipped ecu. i got a po6 that converted to vtec and has a stock gsr base map. but it is not set up for secondary runners if your using a stock gsr intake manifold
Re: Ls V-Tec Build
Re: Ls V-Tec Build
i think this stuff is honestly trend following. i liked the OP's idea simply because he has it all. if it blows, oh well, rebuild time. the rest of these guys who are spending cash are often using high mile b1 bottom ends, spending somewhere around 1200-1500 and thrilled that they made a motor that has similar power to a gsr for around 300-500 less than a jdm gsr. a lot of it is short sighted thinking. i also have a feeling that a lot of the guys are young with limited automotive experience. most of us with time, track events and multiple cars under our belts would dish out that 300-500 more for the real gsr in a second.
Re: Ls V-Tec Build
yea its vtec but when you blow urb16 block and have a ls layin there lsvtec seems like a good way to get ur car rollin again, , and i didnt get a gsr cuz i couldnt find one not many cats have a gsr for sale around indianapolis, why be against ls vtec if done correctly there monsters, i built mines and done everthing right to the tee, so what im gettin at turbo ls vtec= monster
Re: Ls V-Tec Build
Re: Ls V-Tec Build
I'm against it for the reasons I mentioned earlier...I really like B18C1's and C5's...i've had a GSR and now I have a Type-R so, that's pretty much my 'bread and butter'...if I were you, I would have just boosted the car with the LS motor, non-VTEC, possibly utilizing some aftermarket cams and just keep it non-VTEC...I would put my money on a Turbo GSR against a Turbo LS-VTEC anyday. I guess maybe it's just a personal thing...but if you're really into them, go for it, you're entitled to be...i'm just giving my side.
Re: Ls V-Tec Build
i also have a type r
the thing is building an lsvtec right often costs as much or more than buying a jdm gsr engine outright. that's our bitch. if you just happen to have the parts in your shop, sure, great idea. spending a lot to do one, bad idea. you follow?
the numbers on an lsv are fine, it's the long term reliability that suffers unless you tear the block down and upgrade the rods and do a real gram balance on the spintron
Re: Ls V-Tec Build
http://lightningmotorsports.com/ligh.../i-269896.aspx
One thing that isn't taken into account in building a ls vtec vs buying a JDM gsr is you have spent the money on upgrading the fuel system/engine management. So thats something you don't have to pay for to make more upgrades. People who follow trends just to be cool are wasting their time. I'm planning on swapping a gsr head on my car when I get a little extra cash. I'm building up my bottom end right now. Just because you dislike the idea of a ls vtec doesn't mean you should go around and tell everyone it is a bad idea to do it. There is nothing wrong with either route.
Re: Ls V-Tec Build
Here is a link for a full ls vtec kit
Trying to save them some time and money...last I checked, people like to conserve both...and what fuel system/engine management upgrade were you talking about?
Re: Ls V-Tec Build
Well not everyone starts with a stock ls to build off of. In my case I had an extra engine sitting around and had to take a lower engine machining class for school. I was told that I needed to buy pistons to know what I would need to set my bore to so I went out and bought some JDM ITR pistons. Fuel upgrades being injectors/pump. I understand that a stock ls vtec won't need much if any more than stock injectors or pump. Engine management being something like hondata to tune the car with after its put together. Because Honda didn't build a ls vtec they didn't make an ecu for it. Both are things you would need to add more things to your car later.
Re: Ls V-Tec Build
People must feel pretty legit getting an aftermarket ECU for LS-VTEC...I think i'll sell my Type-R and get an LS, make it LS-VTEC, purchase AEM EMS, put my shades on and call it a day.
Re: Ls V-Tec Build
Whatever man, I would be happy with a B18C5 also. I drag race at my local track and will enjoy things like launch control, not that I need it. I've been doing just fine with the stock ls.
Re: Ls V-Tec Build
i purchased my db8 recoverd theft no motor. i got a good deal on a complete b18b for $300. i ran that for mayby 7 months no problem until i came accross a deal on a b16 head for $100/ the head was completly dissassembled but everythnig looked good. then 2 months later i found a complete assembled b16 head for $250 so i manage to sell my first one for the same price and grabbed that one. i spend some money on the lsvtec kit, but all together i got a great motor. it was a good learing experience putting it together. if i had the chance, yeah id do it again. i dont care what anyone thinks about be following a trand of wasting my time. i got a good strong running motor at a great price.
Re: Ls V-Tec Build
