ls/vtec help.
Old Jul 24, 2008 | 06:51 PM
lskid98's Avatar
Default ls/vtec help.
i am getting all the parts togather to do an ls/vtec. so far i have the type R head, intake manifold and header. i know i need the vtec conversion threw golden eagle and vtec solinoid (anyone who has an obd2 solinoid for sale),distributer, wireing and ECU but after that im lost on what else i need to get. some help on what other parts and if anyone has any forsale would be wonderful.
Old Jul 25, 2008 | 07:06 AM
92integraVTECgsr's Avatar
Default Re: ls/vtec help. (lskid98)
B18 block.
Are you building the motor? or just slapping the ITR head a stock a B18 block?
You need:
Head
Block
GE LS/VTEC Kit
What car is this going into? If its going into an OBD2 car, then you also need:
jumper harness
obd1 ecu
someone to tune your car
obd2 dist
vtec solenoid
BUT I advise you to do more research and searching here on honda-tech because if you're building an LS/VTEC and still don't know what all you need, you shouldn't be tackling this job. It's a lot more expensive then you think (if done right).
Old Jul 25, 2008 | 08:03 AM
HONDRETTI's Avatar
Default Re: ls/vtec help. (92integraVTECgsr)
OEM headgaskets work fine with extended head studs. you'll also need a VTEC waterpump and timing belt. depending on the mileage of your block, you really should replace your rods with new ones. your gonna have to tap your oil return line, and wire your solenoid with a OBD1 jumper harness. you can use any VTEC ECU, just get it chipped and tuned.
follow the sticky at b20vtec.com at the top of the B series tech forum, cant go wrong with that.
just my +1
your spelling, -2
Old Jul 25, 2008 | 08:10 AM
DC_Legacy's Avatar
https://honda-tech.com/zerothread?id=1676914
Check it out, theres lots of info about whats needed vs whats optional.
Old Jul 25, 2008 | 08:49 AM
DC_Legacy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integraVTECgsr &raquo;</TD></TR><TR><TD CLASS="quote"> It's a lot more expensive then you think (if done right).
</TD></TR></TABLE> Yes!
deinon
Jun 1, 2006 06:28 AM
Dj Skidz7
Mar 3, 2006 02:49 AM
civic97pr
Mar 21, 2005 01:20 PM
91_civicsi
Nov 9, 2004 07:39 PM
KustomCrx
Oct 24, 2004 12:09 PM
