Low Compression
Old Mar 25, 2009 | 06:48 AM
lsdc4's Avatar
Default Low Compression
Hey guys, I just did an lsvtec conversion on my 2000 integra. I used a 99 gsr head, and now that the head is on I did a compression test and i got 120 through all four. Checked the cam clearances and the were fine. Now when the car starts its fine but as soon as the engine gets to operating temp and I am at a complete stop the engine stalls. I am going to remove the head and have an angle job done as I feel the compression is leaking thru the valves.
Any other troubleshooting tips or ideas?
Old Mar 25, 2009 | 07:35 AM
jdmef9gsr's Avatar
Default Re: Low Compression
do a leakdown test to check where the problem is
Old Mar 25, 2009 | 09:43 AM
MumBleZ_94gsR's Avatar
thats low but at least ur even througout the cylinders
Old Mar 25, 2009 | 09:50 AM
ALLxMOTOR EG's Avatar
Vietnamese!
Yes a leakdown test forsure.GL
Old Mar 25, 2009 | 11:23 AM
Tommy_T's Avatar
x2
Old Mar 25, 2009 | 01:19 PM
lilo_goki's Avatar
x3 on the leakdown test, what was your compression before the head swap?
Old Mar 25, 2009 | 07:25 PM
Goldpow85's Avatar
without cams on add water to intake and exhaust ports and look and see if there water on top of piston.
Old Mar 25, 2009 | 10:42 PM
1992db2's Avatar
Cylinder leakdown or if not, a wet compression test. And try giving it a good valve adjustment. Do both BEFORE you tear anything apart.
MikeD21
Engine Machining & Assembly
14
Jan 3, 2019 10:54 AM
MarkCayabyab
10
Oct 29, 2013 06:18 PM
civic-one
Apr 6, 2011 08:02 AM
SilkyJohnson
13
Feb 15, 2011 05:54 PM
94_civic_tuner
Oct 10, 2007 02:00 PM
