low compression?
Old Nov 21, 2006 | 12:43 PM
RedGSR1994's Avatar
Default low compression?
Ok, so, my car smokes black smoke, and burns about 2 quarts of oil every 2 weeks. Today I ran compression check and cylinder 1 had 150, #2 had 150, #3 had 145, and #4 had 165. Spark plugs had black carbon biuld up (running rich?), idles rough, and kind of low. What does this sound like? timing belt maybe?
Old Nov 21, 2006 | 04:52 PM
supadupamikey's Avatar
Default Re: low compression? (RedGSR1994)
lol, its not your timing belt.
i've got a similar problem, except my compression is 176-180 across the block, i've been trying to do research on it and it sounds like my lower oil control rings are shot. start doing research, its probably your rings or valve seals... or both. im burning a quart of oil every 100 miles or so, so i'm thinking i've got multiple problems.
Old Nov 21, 2006 | 05:05 PM
cranny's Avatar
24.224.233.247
Default Re: low compression? (supadupamikey)
if your burning that much oil its prolly valve seals and guides worn.
Old Nov 21, 2006 | 05:10 PM
DC4 me's Avatar
Default Re: low compression? (cranny)
my car has the same problem except my compression is at 125 all across.
yankie_1132
Sep 22, 2012 08:34 AM
Jamarquis
Jul 3, 2008 11:33 AM
ls94vtec
Jun 26, 2008 11:14 PM
hondaeg8
10
Jul 25, 2004 11:13 AM
Cyber ITR
Mar 4, 2002 06:08 AM
