Low azz compression?
Old Jun 26, 2008 | 10:05 PM
ls94vtec's Avatar
Default Low azz compression?
So check it ,I got around to checking my compression and it wasnt good cyl #1 was 90 psi the wit oil was 160 psi, cyl#2 was 210 psi and wit oil was 235, cyl#3 was 155 and wit oil was 210 psi, cyl#4 was 120 psi and wit oil was 155psi. So I know the rings are crap but what else could cause that low of compression and such a variation between the cylinders. Is it time to look for a new gsr block. Anyone wit an idea help me out please.
Old Jun 26, 2008 | 10:43 PM
SuckMyDOHC's Avatar
english > you. it could be a lot of things, including valve seals. do you see any oil where your spark plugs are?
Old Jun 26, 2008 | 11:14 PM
ls94vtec's Avatar
Default Re: (SuckMyDOHC)
nah no oli near the plugs really, but the car only smokes after about 6,000 rpm the it throws a crap load of smoke. but normal driving no smoke.
eg:R
Jun 4, 2009 08:10 PM
hondaeg8
10
Jul 25, 2004 11:13 AM
Layziebtnh055
Jun 22, 2004 03:25 PM
Bbasso
Sep 17, 2003 03:22 PM
