L/s vtec help
Old 05-22-2004, 12:32 PM
.doeboyfresh.'s Avatar
Location: Boswanna,street radio,riddin in da regal. PA.LLday
Default L/s vtec help
ok i have a 1996 RS ... i just bought evoII exhaust....and greddy 4-2-1 header....all for an RS....now my problem is in the summer im doing the vtec and i need to know if the greddy header for and rs will fit on the gsr head and also the exhaust....becuase if not i guess i have to sell the stuff brand new right. that would really sux beucase then i just wasted my time buying all that stuff when it wont even fit when i do the vtec gsr head...
Old 05-22-2004, 01:48 PM
Darkane's Avatar
Default Re: L/s vtec help (TeGmAn18)
To your question im going to answer in 2 parts. YES and NO.
1) the header will bolt up to the vtec head. The exhaust side bolts up no problem.
2) im not sure after bolting it on to the head it will be at the exact same spot it was at the cat earlier. I think but not sure the Vtec heads' exhaust side is higher or farther out or something. (vtec experts help out!). So I hope that helps. GL!
Old 05-22-2004, 01:59 PM
Quiks66's Avatar
Default Re: L/s vtec help (Darkane)
To answer with one word: yes. When I had my LsVtec built and installed in my '97 RS, i used the stock RS (which is the same as the LS) header and full exhaust system including the catalytic converter. You should have no problems matching up the Vtec head and your existing aftermarket exhaust system.
Old 05-22-2004, 02:40 PM
Default Re: L/s vtec help (Quiks66)
thank u god!!
Old 05-22-2004, 03:00 PM
mntuner2's Avatar
Heh, sweet. I am gonna do one, tune it with turbo-edit and a DB1. Then plop it in a Civic(EF??).
The_SurgeoN
06-11-2015 02:20 PM
NONvtecLSteg
03-20-2014 02:25 PM
T3k C
03-19-2007 02:22 PM
pr1mo_13
07-07-2005 10:58 PM
Quick Reply: L/s vtec help
