itr wing help
itr wing help
when you install an itr wing on a integra that already has the stock wing there are leftover holes right? does anyone have any pics of these holes/what it looks like on? thanks
Re: itr wing help (mrdeadman)
i dont think that there are any holes left, there should be 2 holes on each side of the hatch for a gsr wing and the type r wing and the fitment should be a perfect swap.
Re: (kb12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kb12 »</TD></TR><TR><TD CLASS="quote">yes there are two holes left if you have a gsr. one hole is exposed on each side. you will need to plug it. </TD></TR></TABLE>
actually...on my LS...there was only one "extra" hole on the passenger side. When I read this, I went out and looked at my car Didn't see the other hole.
Re: (Naruto)
yes there are two holes on the gsr trunk i believe the biggger one on the left side has that white piece of plastic, man taht was a bitch takin it out since it was jammed, no they're not visible once u put on the itr wing
i have an oem type r wing on my gsr and i just used some rubber gromets to plug the holes. you can see them. they lay in the inside of the wing. people use different things to plug them and then they paint to match car that way it is not so noticeable. hope this helps.
Re: (spoon_meeH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon_meeH »</TD></TR><TR><TD CLASS="quote">yes there are two holes on the gsr trunk i believe the biggger one on the left side has that white piece of plastic, man taht was a bitch takin it out since it was jammed, no they're not visible once u put on the itr wing</TD></TR></TABLE>
yea I know. I was talking about that extra one where the wiring for the led brake light on the OEM wing went through.
There are 2 hole, I had same problem on my Ls. The drive side one should alrady have a white plug in it, The passenger side is wde open.
Like other sed just get a plug that fit the size, paint it and plug it. Unless you got a creazy Billion dollar Show car its very hard to notice.
But make sure you plug it lol or your car will have an interior pool lol.
