Interior Electrical problem in the DA
Old Oct 19, 2005 | 10:26 AM
red91g2's Avatar
Default Interior Electrical problem in the DA
I've got a 91 ls teg and the interior map lights and my clock along with my radio went out. and sometimes my clock comes back on when started and blinks when the blinker is on any one have any ideas of what happened? or fixing the problem?
also at an earlier date then above my climate control system is stuck where i had it a month ago it doesnt switch anymore and my ac light wont come on any more either, im not sure what the problem is and cant figure it out, does anyone have any input? TIA
Old Oct 19, 2005 | 11:45 AM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
Default Re: Interior Electrical problem in the DA (b18c93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c93 &raquo;</TD></TR><TR><TD CLASS="quote"> I've got a 91 ls teg and the interior map lights and my clock along with my radio went out. and sometimes my clock comes back on when started and blinks when the blinker is on any one have any ideas of what happened? or fixing the problem?
also at an earlier date then above my climate control system is stuck where i had it a month ago it doesnt switch anymore and my ac light wont come on any more either, im not sure what the problem is and cant figure it out, does anyone have any input? TIA</TD></TR></TABLE>
sounds like you need a multimeter and some time. you need to check EVERY fuse in the car and under the hood. Get back to us after that.
IF all the fuses are good, you have a SERIOUS wiring issue...fire hazard style. let me know
Old Oct 19, 2005 | 03:30 PM
4dr_all_day's Avatar
^ agree
Old Oct 19, 2005 | 03:38 PM
stocker2shocker91's Avatar
I requested a short story for a title.
Default Re: Interior Electrical problem in the DA (DAantagonist)
same problem in my 91. it should be a fuse i dont kno off the top of me head but i think it is the first fuse in the middle row. should fix the problem.
Old Oct 20, 2005 | 03:19 AM
red91g2's Avatar
Default Re: Interior Electrical problem in the DA (stocker2shocker91)
would that fuse be under the hood or under the dash? anyone?
Old Oct 20, 2005 | 04:17 AM
Backk InTheDA's Avatar
I hate everything
I'm not sure of the fuse, but in my bro's civic, he blew one, and it was for his dash lights and everything, sounds like a fuse issue.
Old Oct 20, 2005 | 05:34 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c93 &raquo;</TD></TR><TR><TD CLASS="quote">would that fuse be under the hood or under the dash? anyone?</TD></TR></TABLE>
Check them ALL, don't skimp. Make sure they're all good just so you don't have problems waiting to happen. That fuse SHOULD be in the drivers kick...but it is possible it's under the hood
Chris
Old Oct 20, 2005 | 05:37 AM
AllMotorDA9's Avatar
Default Re: Interior Electrical problem in the DA (BuilttB18C5)
Im having the same problem with my map light, dome light , clock, and cig. lighter. They all run from one fuse, each time i put in a new fuse it blows it, even when i replace it with a higher watt fuse. I know for sure im shorting out somewhere, but im having a really hard time finding where its shorting out at. Does anybody know where the interior grounds are? I want my damn clock to work, im sick of looking at my cell phone.
Old Oct 20, 2005 | 05:43 AM
Default Re: Interior Electrical problem in the DA (AllMotorDA9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorDA9 &raquo;</TD></TR><TR><TD CLASS="quote">Im having the same problem with my map light, dome light , clock, and cig. lighter. They all run from one fuse, each time i put in a new fuse it blows it, even when i replace it with a higher watt fuse. I know for sure im shorting out somewhere, but im having a really hard time finding where its shorting out at. Does anybody know where the interior grounds are? I want my damn clock to work, im sick of looking at my cell phone. </TD></TR></TABLE>
I dunno where the grounds are...but if you are dealing with a direct short, it's not THE GROUND that's the problem. It's one of the switched +12v wires or constant +12v wires. Start with the radio/cig lighter...make sure you're not getting any direct shorts behind the dash...just check the wires and make sure you get a GROUND ONLY ON THE GROUND WIRE...if you find you have a ground on the wire that supply's 12v, then you have found your problem. Hit me up if you need help.
Old Oct 20, 2005 | 08:23 AM
red91g2's Avatar
you kinda stealing my thread there all motor, but sounds like your 12v wire is grounded more than once when it doesnt need to be, blew a couple of my fuses that way, any way bump
Old Oct 20, 2005 | 09:19 AM
my bad...
Old Oct 20, 2005 | 09:31 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c93 &raquo;</TD></TR><TR><TD CLASS="quote">you kinda stealing my thread there all motor, but sounds like your 12v wire is grounded more than once when it doesnt need to be, blew a couple of my fuses that way, any way bump</TD></TR></TABLE>
hows your stuff going?
Old Oct 20, 2005 | 03:52 PM
under the dash
Old Oct 20, 2005 | 03:55 PM
yea all motor i had the same prob i have a 30 amp fuse in there now it blows sometimes for no reason one time i just pulled the e brake in my yard and did a donut, blew the fuse for some reason. voltage spike somewhere
Old Oct 22, 2005 | 02:11 PM
red91g2's Avatar
fixed it thanks everyone
Old Oct 22, 2005 | 04:40 PM
what was it so we all know eh?
Old Oct 24, 2005 | 03:03 AM
red91g2's Avatar
dumb little 10amp fuse !!!
Old Oct 24, 2005 | 05:37 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c93 &raquo;</TD></TR><TR><TD CLASS="quote">dumb little 10amp fuse !!!</TD></TR></TABLE>
figures right
glad you got it all fixe up man
Old Oct 28, 2005 | 04:19 PM
red91g2's Avatar
thanks for the help
ONEK211
Acura TSX
14
Jun 7, 2008 01:42 AM
Ack0six
Jun 11, 2007 08:01 PM
Saiyansniper
Mar 21, 2005 07:40 PM
Stewie
Jan 8, 2005 06:04 PM
