rubbing problem
Old Oct 28, 2005 | 09:42 AM
boosted94teggy's Avatar
Default rubbing problem
hey alirhgt well before i cahnged my cv joints there is this really loud nosie coming from the front at first i thought it was just my cv joints cuz they are fucked up bad like the whole boot is out but today i fixed the right one and it is still making that same noise and now i wonder if it is actually the tires rubbing because it sounds like that and i have 215 50 17's on there does anyone know what the problem is if u have had it or what thanks
Old Oct 28, 2005 | 09:44 AM
Lewie's Avatar
I'm here for the gangbang!
Awful grammar
How low is your car? I highly doubt it's the tire, but your paragraph/sentence is hard to understand what you're actually saying.
Old Oct 28, 2005 | 09:50 AM
MenaceL.A.671's Avatar
Default Re: (Lewie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lewie &raquo;</TD></TR><TR><TD CLASS="quote">Awful grammar
How low is your car? I highly doubt it's the tire, but your paragraph/sentence is hard to understand what you're actually saying.</TD></TR></TABLE>
dayum your tires are BIG!
Lewie's Avatar
Default Re: (m2slsvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m2slsvtec &raquo;</TD></TR><TR><TD CLASS="quote">
dayum your tires are BIG! </TD></TR></TABLE>
Not that big. I had 215/40/18's on my car a year ago.
No rubbing
Edit: It actually did rub when I tried to do a u-turn and turned the wheel all the way left or right, but it didn't rub otherwise.
3-point turns y0!!!
Old Oct 28, 2005 | 10:11 AM
Default Re: rubbing problem (boosted94teggy)
alright well i noticed the cv joint boots were completey shot and my dad gave me his old tires of his maxima and just a little while ago i heard like a loud repetitive noise and i thought that maybe it was the cv joints but i fixed them today and it still makes a rubbing sound i have stock suspension when i turn it rubs bad and when i turn the wheel all the way it rubs so do u think it is the tires rubbing or something else like in the transmission or what
Old Oct 28, 2005 | 03:43 PM
Eluzions047's Avatar
Well, I had that problem b4. I had on 17/40/215, and then I finally decided to raise it back up and rolled the quarter panels and stuff. That took care of that. If you want to just get rid of that problem once and for all - go with 17/40/205's.
Old Oct 28, 2005 | 03:45 PM
Default Re: rubbing problem (Eluzions047)
well i dont think it is a tire rubbing problem because it only does it when i am on the throttle
Old Oct 28, 2005 | 04:30 PM
skitteledteggy's Avatar
rolled the quarter panels I had to do that with mine...What kind of grinding noise is it? Metal on metal? or some other I know that before I changed my Tie rod ends I had horrific noises coming from the sides of my car, but You said that it happened when you got on it. so I dont think that it could be suspension I think you should have your car stationary rev it, and then figure out where it is coming from and if it only happens when you are going down the road, I would look into having your tires put back on your car instead of the max wheels.
recaroem2
Honda Civic (2001 - 2005)
12
Oct 12, 2007 02:55 PM
Wicked04
Honda S2000
Apr 27, 2007 03:44 PM
hondafrk505
Nov 14, 2006 09:11 PM
FOMULA91
14
Mar 29, 2006 07:22 AM
94redsol
11
Mar 9, 2004 11:14 AM
