Injectors...
Old Sep 21, 2004 | 01:02 PM
rayscar's Avatar
Default Injectors...
What is another name for the injectors b/c my repair manual doesn't have anything in the index as injectors??
Would the injectors be the cause for my engine having a rattle somewhere around the exhaust manifold? I have been told it is, so what do ya fellas think? Can you help me? Gracias!
Old Sep 21, 2004 | 01:14 PM
evil_schmevil
Guest
Posts: n/a
Default Re: Injectors... (rayscar)
huh, injectors causing a rattle around the exhaust manifold?
Sounds like someone is blowing smoke up your pipes to pad a repair bill.
A rattle around the exhaust manifold is probably a loose heat shield or downpipe hanger bracket or some **** at least close to the EM.
Old Sep 21, 2004 | 01:22 PM
CalGSR99's Avatar
Default Re: Injectors... (evil_schmevil)
Tell that mechanic to go **** off. Its probably some lose bolts. Injectors arent even located close to the exhaust manfild or have any direct physical communication.
Old Sep 22, 2004 | 07:20 AM
rayscar's Avatar
Default Re: Injectors... (CalGSR99)
My bad!
I phrased my question wrong. I have been told the rattle could be something to do w/the exhaust manifold or the injectors. However, when I try to locate the rattle it's around the Intake manifold on distributor side. What could it be?
Old Sep 22, 2004 | 07:31 AM
rayscar's Avatar
My bad,
Phrased the question wrong. Rattle is around intake manifold, distributor side. Other people have said rattle could have something to do with exhaust manifold.
totsie7944
Mar 3, 2008 07:09 AM
steinar
Nov 18, 2007 06:18 AM
DaveF
May 20, 2004 11:41 AM
ebpcivicsi1234
Feb 13, 2004 08:37 PM
