Inconsistent clutch engagement point.
Sometimes clutch engages at the bottom of the pedal travel, sometimes at the top.
It is difficult to drive because every time I have to try it carefully.
Did anyone experience similar problem? What could it be?
Re: Inconsistent clutch engagement point. (MrSmith)
Same happens to me. I have not figures it out yet, but I believe its the slave cylinder. I noticed mine has a very very small leak and i think it may be allowing air into the system, which will give you the inconsistancies. Try bleeding the system and replace if neccessary.
Re: Inconsistent clutch engagement point. (VTECAcuraGSR)
my slave cylinder was replaced about 10k miles ago and everything was bled a month ago. No leaks anywhere. Could the problem still be with the slave even if its not leaking? or could something else be causing it?
When I had my ACT XTSS put it they told me the excess pressure could cause my master or slave cylinders to fail. You could start by looking at that.
Re: Inconsistent clutch engagement point. (Virtos)
My car still have tiny milage, so I took it to a dealer today and claim a warranty problem.
They spent about an hour with it and returned with the verdict "Not a problem". Also they said even if they could recreate the problem, they would not be able to do anything about it.
Re: Inconsistent clutch engagement point. (Cheap Bastard)
i have act heavy duty pp with organic disc about 8k miles on it... fawking remanufactured pos! What could be causing the problem? The clutch disk/pressure plate what?
vanish1
06-29-2008 05:53 PM
