Immobilizer System light won't stop blinking...
Old 11-16-2005, 04:14 PM
RuskeR's Avatar
Default Immobilizer System light won't stop blinking...
So, I think this may be what is causing my car to not start. I noticed while checking the relays in the car that the immobilizer light blinks in the ON (II) position. From what the manual says, I'm fucked.
Does the key need to be re-coded? Need to buy new keys? Anyway to reset this system.
I'm glad my car came with this system to help protect it from being stolen, but dammit.
Any ideas?
Fixed
https://honda-tech.com/zerothread?id=1431468
Modified by RuskeR at 8:35 PM 7/10/2007
Old 11-16-2005, 05:32 PM
Lauj87's Avatar
ecu might just need to be reset.....iono...
Old 11-16-2005, 06:39 PM
2kgs-R's Avatar
Default Re: Immobilizer System light won't stop blinking... (RuskeR)
Have you tried using a spare key? If it doesn't start you'll probably have to get your key's reprogrammed with the code thats in the ecu, and the only way to do that is to bring the key and car to the dealership.
Old 11-16-2005, 08:15 PM
RuskeR's Avatar
Default Re: Immobilizer System light won't stop blinking... (2kgs-R)
the keys AND the car?
Old 11-16-2005, 08:19 PM
RuskeR's Avatar
I tried using the Valet key and it didn't work. The extra key isn't in my possesion at the moment.
Old 11-18-2005, 09:06 AM
RuskeR's Avatar
Old 11-20-2005, 06:50 PM
RuskeR's Avatar
Would this be caused by a bad ICM?
Old 11-22-2005, 10:57 AM
RuskeR's Avatar
Default Re: (RuskeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RuskeR &raquo;</TD></TR><TR><TD CLASS="quote"> Would this be caused by a bad ICM?</TD></TR></TABLE>
Old 01-30-2006, 10:40 AM
purehonda's Avatar
bump, today was the second time this month this has happened. The first time, i turned the wheel a few times and it stopped flashing. Today, I tried both of my keys, neither worked. Then after about 5 minutes of trying both keys. one worked. Someone help us out!
Old 01-30-2006, 02:46 PM
B A N N E D
OneTyteEK9's Avatar
Just get a obd2-obd1 wiring harness with an obd1 ecu and use your key and then your car will start
Old 01-30-2006, 07:10 PM
purehonda's Avatar
Default Re: (OneTyteEK9)
I already have that, just not installed yet. I'm about to setup a custom s/c, but still have a few more parts to buy. Just need to make it a few more weeks on obd2.
Old 01-30-2006, 08:11 PM
finest_GSR's Avatar
i lost my key once on my 2000 gsr....my spare key wouldn't start....i later found out that the 99-01 model has that anti-theft immobilizer ...only the key with the chip (has to be the right code for the ECU) can start the car...without it your fuel pump won't start.....a locksmith came and made me two new chipped keys and also change the old code to a new one..for about 120 bucks....if low on budget...ask around for an 0bd2 to 0bd 1 conversion harness...an 94-95 ecu and change the distubutor...it should start the car.......SSSSHHHHH...that how the expert steal these cars
Maggie9123
Honda CR-V & Element
03-18-2014 05:07 PM
4 door beast
02-25-2010 04:35 AM
Blackened1
07-27-2009 10:55 AM
menpachi
Honda Civic (2001 - 2005)
10-30-2007 03:01 PM
EFz6er
02-07-2004 03:18 PM
Quick Reply: Immobilizer System light won't stop blinking...
