Weird Idle Issue
Old Oct 16, 2011 | 12:43 PM
Dannyx321's Avatar
Default Weird Idle Issue
I got a 94 gsr and i recently put a new blox manifold on, car idled fine for about 2 months and then when i was going fast against another car, idle went up to 1.5 and just sits there
There are no vacuum leaks, but there some awkward tin foil sticky tape stuff covering two holes on the inside of the throttle body, removing them cause a even higher idle surge (from 1 to 3)
My Friend told me that i need a new throttle body, since i have a aftermarket on.
So I just want to know if buying a new throttle body will fix my idle? (i have done the screw thing on the top of the throttle body)
Old Oct 17, 2011 | 01:58 PM
Dannyx321's Avatar
Default Re: Weird Idle Issue
help me lol bump
Old Oct 17, 2011 | 05:40 PM
mouab18c1's Avatar
New TB will not solve your problem.
Is your tb cable sticky? Have you bled the coolant system?
bmxfelon420
Mar 20, 2010 04:11 PM
magicguy
Jan 30, 2009 02:00 PM
black bandit
Jan 14, 2008 04:26 AM
