HVAC problem
Old Oct 13, 2004 | 10:28 AM
tnord's Avatar
Default HVAC problem
well, it's finally getting cold here in kansas, and it was raining the past couple of days. rain + cold outside = need defroster.
well, apparantly my defroster crapped out on me. and actually, the only place air will come out is through the dash vents. it's also very difficult to slide the temperature control **** from cool to warm.
anybody else have this problem and know what it is? know how to fix it?
Old Oct 13, 2004 | 02:00 PM
Bbasso's Avatar
Default Re: HVAC problem (tnord)
Sounds like one of the cable or cable guides have come loose or broken, I suggest taking apart to sneak a look.
Also try some spray lube on the cables to let them slide easier.
Old Oct 13, 2004 | 02:50 PM
mstewar's Avatar
what rob said.. that's usually the cause when you can't slide the thing.. if all looks good with the cables, I'd pull the HVAC controls to check their operation.. should be pretty easy..
Old Oct 13, 2004 | 08:57 PM
tnord's Avatar
Default Re: HVAC problem (mstewar)
doesn't sound like the whole dash needs to come out does it? on my old BMW you had to take the whole ******* thing apart to change 1 little bulb. looked and fit great, but sucked to work on.
i've ripped out mazda stuff before, but never honda's. if a cable has just come off and i can just take out the center section........well i'd be a happy boy.
Old Oct 14, 2004 | 07:22 AM
mstewar's Avatar
you shouldn't have to take the whole dash out.. possibly the center section.. pulling the glovebox would make things easier as well.. otherwise, the dash should remain intact..
pulling the dash on an integra is not THAT hard anyhow..
pmp
25
Oct 5, 2011 09:13 PM
navin
Dec 16, 2007 10:04 PM
94_CRVtec
Oct 29, 2004 02:06 PM
smfernando
Sep 1, 2003 08:31 PM
Infinity_Racer
Oct 17, 2002 09:37 AM
