Heater Control Dash Problem Please Help
http://cgi.ebay.com/ebaymotors/HONDA...item5ae2c76d8d
the hot and cold switch on this. I was moving the switch from cold to hot and it like got stuck and it felt like somthin broke now only the cold side works. when i put it on hot no heat comes out. Would this be maybe the cable disconnected. Please help. LEt me know if this is an easy fix or what. THanks
Also the lights in this part keep goin out and i hit it and usually it comes back on how would i change the bulbs?
Thanks
Thanks
Re: Heater Control Dash Problem Please Help
i went to move the hot/cold **** to hot and moved it back and it got real tight now its really loose. it only blows cool air now no heat. and winter is around the cornor.
Grab hold of the cable, pull it toward the firewall to create tension, and move the temp lever back and forth. Do you feel the cable move at all?
theres like too much cable when i move the switch back and forth i dont even see where the cable is attached to move at all
