how to replace alternator?
Old Nov 28, 2006 | 01:40 PM
  #26
gsrclan's Avatar
Default Re: (crxma22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxma22 &raquo;</TD></TR><TR><TD CLASS="quote">i pulled my alternator on my 98ls from the top? everything was fine? just had to wiggle it out...</TD></TR></TABLE>
Are there any other differences between ls and GSR besides the tower brace bar, that will make alternator change different?
Old Nov 28, 2006 | 01:42 PM
  #27
gsrclan's Avatar
Default Re: (Robstunner4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Robstunner4 &raquo;</TD></TR><TR><TD CLASS="quote">i replaced mine 6 moths ago myself. take off the front black bar on the bottom and ull be fine. its a tight fit</TD></TR></TABLE>
I am a little unclear, did you remove the front sway bar and pull it from underneath?
Old Nov 28, 2006 | 01:57 PM
  #28
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (gsrclan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrclan &raquo;</TD></TR><TR><TD CLASS="quote">I checked 94 manual, the procedure is the same. I looked at my car and agree there are lots stuff in the way.</TD></TR></TABLE>
The GS-R intake manifold and the vacuum canister that controls the butterfly valves takes up a TON more room than the LS manifold does.
If someone with a GS-R and stock intake manifold has pulled out their alternator from above, I'd sure like for someone to show me how to do it.
Old Nov 29, 2006 | 04:39 AM
  #29
Robstunner4's Avatar
I am a little unclear, did you remove the front sway bar and pull it from underneath?</TD></TR></TABLE>
yea sorry i didn't write that like i wanted. the front lower tie bar is what i meant.
Old Nov 29, 2006 | 05:09 AM
  #30
Community Builder
I looked at my Helm's manual, and it does say to pull it out from the top, but it also says to unbolt both the upper and lower brackets that hold the alternator, so I don't know if that would help or not.
I looked at my car, and to me it looks like the combination of the end of the fuel rail + the fuel pressure regulator, the intake manifold and vacuum canister, the power steering hose, and the brake master cylinder all make it way to crowded to pull it out from the top, at least on a GS-R.
Old Nov 29, 2006 | 05:14 AM
  #31
be.twenty's Avatar
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">The GS-R intake manifold and the vacuum canister that controls the butterfly valves takes up a TON more room than the LS manifold does.
If someone with a GS-R and stock intake manifold has pulled out their alternator from above, I'd sure like for someone to show me how to do it.</TD></TR></TABLE>
you can't do it on an LS either..... i tried
all helms says is to take off the top and bottom brackets. it does not say remove from the top or bottom.
Old Nov 29, 2006 | 06:12 AM
  #32
Community Builder
Default Re: (be.twenty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by be.twenty &raquo;</TD></TR><TR><TD CLASS="quote">you can't do it on an LS either..... i tried
all helms says is to take off the top and bottom brackets. it does not say remove from the top or bottom.</TD></TR></TABLE>
It does say to lift it out.
Old Nov 29, 2006 | 06:47 AM
  #33
teg_timmyc's Avatar
Default Re: how to replace alternator? (ge_itr)
just loosen all the belts, take all the belts off, loosen alternator bolts, pull alternator out the top. on my DA it is even easyer if you take off the power steering pump.
Old Nov 29, 2006 | 07:11 AM
  #34
be.twenty's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">It does say to lift it out.</TD></TR></TABLE>
well waddaya know... hey it also says to check the radio code! lol....
Old Aug 6, 2007 | 09:40 PM
  #35
AZDB8's Avatar
Default Re:
Just to throw my two cents in, in case anyone else checks this thread...
I just changed the alternator in my 94 GSR, and tried it from the top. It looks like there's no way it can come out the top, but it is actually not that difficult.
Unbolted power steering, master cylinder (without disconnecting brake lines), and moved the wires running above the alternator. I removed the top alternator mount, and unbolted from the bottom mount.
I just pulled the master cylinder away from the brake booster, and moved it out of the way without disconnecting lines, so I would not have to bleed it. With the power steering hose pulled out of the way, the alternator slid right out with some maneuvering, and the new one back in.
EM-One
Jun 23, 2007 07:15 PM
bravo76
Jan 17, 2007 08:54 AM
dlowdog
Dec 30, 2005 07:42 PM
97VtecIN
Nov 7, 2004 08:52 AM
SilverDc2
Jun 10, 2003 07:53 PM
