How could water leak into the car?
Old Oct 14, 2002 | 10:46 PM
shamoo's Avatar
Will you make something up for me please?
Default How could water leak into the car?
I posted this in Members:
https://honda-tech.com/zerothread?id=306991
Do any of you know how water could have gotten in there? I know I didn't leave a window open or the sunroof open. The sunroof isn't leaking...otherwise there wouldn't be water under the rear seats and pooling in the spare tire well.
Any ideas? Thanks.
EDIT: Here are the pics again anyway:
This is the spare tire well:
All that dark stuff is water under the rear seats.
I took out the carpets cuz they were soaked and they started to smell.
Here's the shot from the rear....maybe I should just make my car a drag car, cuz I know I'll be so lazy to put everything back in.
[Modified by shamoo, 2:48 AM 10/15/2002]
Old Oct 15, 2002 | 04:59 AM
JDiMageDC2's Avatar
Default Re: How could water leak into the car? (shamoo)
I dealt with this same problem. It sux. You need to replace your taillight seals/gaskets and your lights may be leaking water through small cracked areas in the lenses you may not notice. Replace the seals and your problem should be solved. I thought I had a hole in the trunk well mine were leaking so bad.**** was an inch deep and like yours, all the way under the rear seats. Big *** mess. Air dry your interior and replace those seals. Good luck.
Old Oct 15, 2002 | 06:46 AM
b18bvtec4drteg's Avatar
Holy shat!
I had the same problem; but only in the rear spare tire area. I replaced the tailight seals and water never came back. BUt you have it all over the car so Im not sure....
Old Oct 15, 2002 | 07:03 AM
fiebru1119's Avatar
Default Re: How could water leak into the car? (b18bvtec4drteg)
I had the same problem.. and it was the tail lights. The water was so deep i could hear it swooshing around when I took turns
Old Oct 15, 2002 | 07:09 AM
Dan GSR's Avatar
Default Re: How could water leak into the car? (fiebru1119)
Anyone know the part number for the tail light gasket/ seal ??
Old Oct 15, 2002 | 07:25 AM
g_man80's Avatar
Default Re: How could water leak into the car? (Dan GSR)
Definitely replace the seal, but like GSRTUNR look at the tailights themselves. The water might be getting in the inside of the light through the smalls gap that runs around the light where there are pressed together, which should be sealed from the factory. I just ran a small bead of clear silicone around the perimiter and smoothed it in the crack with my finger. Then just a little reducer or paint thinner to clean up the light.
Good Luck
G
Old Oct 15, 2002 | 07:30 AM
Bimmer99's Avatar
Default Re: How could water leak into the car? (g_man80)
check to make sure your sunroof drain tubes aren't restricted or some how disconnected. i've seen this happen from that
Saeo
11
Oct 3, 2009 01:43 PM
citrus3000psi
May 19, 2008 02:52 PM
tcontesh
May 2, 2006 07:08 AM
charlieway
Apr 30, 2004 03:23 PM
8alaRm
Jan 9, 2003 08:24 AM
