Help: starter problems
Old Nov 11, 2004 | 02:14 PM
5po0n_Dc2's Avatar
Default Help: starter problems
I have a 96' integra and I'm having problems with my starter. I just installed a new starter and it still won't turn over. When I try to start it, it makes that "starting sound" but doesn't turn all the way. What is the problem?
Old Nov 11, 2004 | 04:17 PM
Cjsls's Avatar
Default Re: Help: starter problems (5po0n_Dc2)
Grounds all connected??Also how's the battery?
Old Nov 12, 2004 | 03:52 AM
JimBlake's Avatar
Describe that 'starting sound' a little better. It almost sounds like the starter is OK but the engine won't fire.
All the starter's supposed to do is spin the engine. If your old starter did that, it wasn't bad in the first place. Your problem was elsewhere. Got fuel? Got spark?
Old Nov 13, 2004 | 04:00 PM
5po0n_Dc2's Avatar
Default Re: Help: starter problems (JimBlake)
It makes that "starting sound" like when you turn the key it sounds like it is about to start but the engine doesn't fire up. I don't know whats wrong. I have a new optima battery too, so I know for sure it's not the battery. I don't know what it could be. Anymore thoughts?
Old Nov 13, 2004 | 05:55 PM
Oleg's Avatar
yep....check the fuses.
Old Nov 15, 2004 | 04:05 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5po0n_Dc2 &raquo;</TD></TR><TR><TD CLASS="quote">It makes that "starting sound" like when you turn the key it sounds like it is about to start but the engine doesn't fire up. I don't know whats wrong. I have a new optima battery too, so I know for sure it's not the battery. I don't know what it could be. Anymore thoughts?</TD></TR></TABLE>Sounds like the battery & starter are OK. That leaves about 400 other things it MIGHT be.
Gotta start to narrow it down. Turn the key ON, but not all the way to START. Does the alternator & oil idiotlights come on? What about the check-engine light?
Do you know how to check for spark? Check for fuel?
Old Nov 15, 2004 | 05:00 AM
B18A1VtecTurbo's Avatar
Same thing happend to me. Theres a really big fuse that controls your electronic fuel pump make sure its not blown!!
Old Nov 21, 2004 | 04:24 PM
hondasniper's Avatar
You also might have corrosion in your main relay. I jumped my buddie's starter by connecting the positive end with the negative end with a wire while he turned the key. It worked for some reason. His car starts up just fine now.
Old Nov 22, 2004 | 12:00 PM
5po0n_Dc2's Avatar
My car has been sitting for about 2 months. There are no check engine lights that light up. I also installed new spark plugs and still no go. I'm going to check fuel injectors, might be ecu. Anymore suggetions would help, need to start ASAP. Again, thanks a lot for replying.
Old Nov 22, 2004 | 08:25 PM
Try to change your main ignition relay. Try to find someone with the same car and try to swap them out. I'm pretty sure that's what it could be.
Old Nov 24, 2004 | 03:37 PM
5po0n_Dc2's Avatar
Default Re: Help: starter problems (hondasniper)
EUREKA! Got it to start. I'd like to thank everybody that helped me out, all you guys were great. Thanks for replying.
Old Nov 24, 2004 | 03:47 PM
Cjsls's Avatar
what was it?
Touge Tuning
May 3, 2006 11:14 AM
5lugSlug
Jul 13, 2005 06:41 AM
5spdIntegra
Mar 26, 2004 12:54 PM
mingchi69
Jul 14, 2003 06:14 PM
RCautoworks
Jan 17, 2003 10:19 PM
