Clutch pedal dead.
Clutch pedal dead.
so in the past few days, id get in my car and press the clutch in to start it, then release the pedal. but it wont pop up, i had to pump it a couple of times to get it to spring back up. pretty much anyime it sits for a period of time it does this. and seems to be getting worse.
what do you guys think it might be?
Clutch master cylinder?
worn out clutch line?
re-bleed the system?
Re: Clutch pedal dead. (ieatrice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ieatrice »</TD></TR><TR><TD CLASS="quote">u need to bleed ur clutch</TD></TR></TABLE>
needs to check fluid first. if problem presists then bleed.
