Help I have 3 error codes
Old Apr 28, 2007 | 05:42 AM
oh_lee_allen's Avatar
Default Help I have 3 error codes
Hello I just did the check on my ecu due to my cel was on and i got these three codes off my p72 obd1 integra.
17 - VSS
23 - Knock Sensor
41 - Primary Oxygen Sensor - Heater
circuit malfunction
I had trouble with my VSS before with my speedo not working but I cleaned the plug and it as worked fine ever since. But it is still throwing these codes at me.
Whould any of them make my car idle up and down. from 2.5k to 1k. I thought it was a vacuum leak but I checked them and I don't see any...I sprayed soapy water to look for a leak and none was found.
Any Help would be great.
Old Apr 28, 2007 | 06:33 AM
Default Re: Help I have 3 error codes (oh_lee_allen)
Well I fixed 2 of the three... I only have the o2 sensor left... it is uplugged but not from the cat but from where ever it plugges in to. all i have is the sensor with wires on it and no plug... where does this plug in to or do i have to run wires to some were. And I still have the same idle problem
OgulcanTR
Sep 13, 2018 10:09 PM
chevy383
Jan 1, 2014 02:39 PM
jlbarrios
Aug 13, 2012 02:44 PM
luispequeno
Dec 13, 2010 09:16 AM
jaycrxsi
Aug 31, 2006 05:04 PM
