HELP!! How much for another engine??
Old Jun 1, 2005 | 10:08 PM
DirtyD12Dozen's Avatar
Default HELP!! How much for another engine??
I might buy a 94 coupe but the engine is blown.
how much would it cost to rebuild? how much for a newer/better engine? I'm in cali. and we gotta deal with the smog b.s. so i cant get just any engine. ANY help is greatly appreciated!
Old Jun 1, 2005 | 10:10 PM
numbnuts22715's Avatar
well rebuilds would probbaly cost more. The easiest thing to do would probably be order a longblock from hmotorsonline.com Get the USDM version, and the engine from the same body type (i.e. LS or GS-R) and just make sure its the same year or newer, and that should be pretty much all you have to do.. I dont know much about it, since Im not in Cali, I dont have to worry about all the smog crap.
Old Jun 1, 2005 | 10:13 PM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
Default Re: HELP!! How much for another engine?? (DirtyD12Dozen)
Rebuilding will run you about $300-$600, depending how much of a rebuild you want to go. And that's without labor.
You're near me, I live in Hacienda Heights. I can get you a good engine for about $500 with low miles. I can install it too for $200 bucks. It'll take me a weekend to get it going.
PM me if you're interested...
Old Jun 1, 2005 | 10:25 PM
Default Re: HELP!! How much for another engine?? (carma_626)
^^yea i live in norwalk. well how much would it be to rebuild my engine?
Old Jun 2, 2005 | 11:07 AM
bump
Old Jun 2, 2005 | 01:34 PM
bump! i needa to find out if i should buy this car or not
Old Jun 2, 2005 | 01:43 PM
xteg95's Avatar
how much is the car going for?
most shops at least around here will charge around 1500 for parts/install on a stock b18b rebuild.
Old Jun 2, 2005 | 04:23 PM
jaydeemmmm's Avatar
Default Re: (numbnuts22715)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numbnuts22715 &raquo;</TD></TR><TR><TD CLASS="quote">well rebuilds would probbaly cost more. The easiest thing to do would probably be order a longblock from hmotorsonline.com Get the USDM version, and the engine from the same body type (i.e. LS or GS-R) and just make sure its the same year or newer, and that should be pretty much all you have to do.. I dont know much about it, since Im not in Cali, I dont have to worry about all the smog crap.</TD></TR></TABLE>
^ It would be wise just to purchase a longblock. I live in Cali. and "supposely" the law requires you to swap the same kind of motor matching your vehicle. The motor has to be the same year or newer than your vehicle. It's possible you might need to state ref it afterwards. Cali is a bitch. Let's all go to Florida!
Old Jun 2, 2005 | 04:32 PM
riceball777's Avatar
complete engines cost
b16 $1000-1200
gsr 3000
itr 4200
ls 600-1000
Old Jun 3, 2005 | 11:44 AM
Default Re: HELP!! How much for another engine?? (riceball777)
thanks guys
how much more does a b16 push than an ls?
Modified by DirtyD12Dozen at 1:51 PM 6/3/2005
Old Jun 4, 2005 | 11:12 AM
bump
Old Jun 4, 2005 | 11:32 AM
old_school_dohcvtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DirtyD12Dozen &raquo;</TD></TR><TR><TD CLASS="quote">thanks guys
this issue has been debated a few times and the conclusion to most people is that the B16a has less torque and your better off getting a LS motor instead.
IMO, i think a b16a is not too bad in an integra but for the price difference, yea LS its probably a wiser choice. In Japan, their EK sedans had a b16a in it and the wieght between an EK sedan and DC are nearly identical
Old Jun 4, 2005 | 11:54 AM
HARI.'s Avatar
Default Re: HELP!! How much for another engine?? (old_school_dohcvtec)
just buy the long block and install it yourself
http://www.hmotorsonline.com/s...30023
and you can pick it up too, since you are local, and he won't charge you tax
Old Jun 4, 2005 | 01:46 PM
Default Re: HELP!! How much for another engine?? (DA9-hari)
thanks guys
Old Jun 5, 2005 | 10:23 PM
anybody else?
Old Jun 6, 2005 | 03:40 PM
bump
Old Jun 6, 2005 | 04:08 PM
crxchris's Avatar
just my 2 cents but i wouldnt recomend having your engine rebuilt unless neccasary(aftermarket components) it would be cheaper/safer to buy a new longblock($$) or a used long block which u can get for around$800 again just my opinion
Old Jun 6, 2005 | 04:20 PM
jennifermike's Avatar
Default Re: HELP!! How much for another engine?? (crxchris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DirtyD12Dozen &raquo;</TD></TR><TR><TD CLASS="quote">anybody else? </TD></TR></TABLE>
yea dont put a b16 in a dc/db
Old Jun 6, 2005 | 04:21 PM
redGSRguy's Avatar
Anyone know the list of parts you need for a rebuild? My car is burning oil and I want to solve this problem once and for all.
To the OP buy the car and make it into a monster! You should bargain it down as much as you can since you are buying a car that doesn't run.
cryingsuns
Southern California
Mar 18, 2011 07:29 AM
blindpug
16
Jan 28, 2005 04:38 PM
LB CRX
Jul 13, 2003 03:14 PM
