help: driver side windows arent working
Old Nov 6, 2005 | 12:01 PM
H.'s Avatar
H.
Default help: driver side windows arent working
well this happend last night i rolled down my driver side window all the way down and i tried to roll it back up but it wont rool up. The rest of the windows work fine power windows and power door locks work fine as well its just the driver side window that wont roll up. I cheked the fuse already and its not burnt. suggestions?
Old Nov 6, 2005 | 12:20 PM
Backk InTheDA's Avatar
I hate everything
Default Re: help: driver side windows arent working (SoCalGsR1)
Is this by any chance on a G2? Because since I've had mine, the passenger side has always, and continues to roll up alot slower than the driver, I associate this w/ a going motor.
I would check that on your car before you get into deeper troubleshooting.
Old Nov 6, 2005 | 12:22 PM
H.'s Avatar
H.
Default Re: help: driver side windows arent working (BuilttB18C5)
nah its not a DA its a 96 integ....BTW why do u have jason from LB on ur avatar?
Old Nov 6, 2005 | 12:36 PM
I hate everything
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoCalGsR1 &raquo;</TD></TR><TR><TD CLASS="quote">BTW why do u have jason from LB on ur avatar? </TD></TR></TABLE>
Haha, yeah I love that show, anyways, back on topic have you tried looking at the motor? Because, I have heard of those things going bad on tegs, especially the passenger side.
Old Nov 6, 2005 | 12:38 PM
H.'s Avatar
H.
nope i havent looked at it yet. Where is it located ?
Old Nov 6, 2005 | 12:43 PM
I hate everything
I'm not sure exactly, I looked on https://www.acuraautomotivepar...y.jsp for a digram, I couldn't find one, try a search, or take off the door panel, and take a picture of it, post it here, and hopefully someone can help.
Modified by BuilttB18C5 at 1:57 PM 11/6/2005
Old Nov 6, 2005 | 12:45 PM
H.'s Avatar
H.
k thanks for the help
Old Nov 6, 2005 | 12:54 PM
I hate everything
No problem man
Old Nov 6, 2005 | 02:28 PM
JMD's Avatar
JMD
I work at Nissan and the window regulators go all the time and its the same symptoms. When you push the button, do you hear the motor or no? I would take the door panel off and check the regulator cable. Alot of times they get chewed up.
Old Nov 6, 2005 | 02:30 PM
chahsiubow's Avatar
Open and close the door with the button depressed and see if it goes up. If it does, the weather stripping needs to be replaced. Otherwise, if the motor doesn't sound funny or weak, check for loose connection or bad wires.
Old Nov 6, 2005 | 04:56 PM
H.'s Avatar
H.
Default Re: (chahsiubow)
ok i fixed it, it was a loose connection i opend the door panels and saw that there was a loose connection. Thank god it wasnt the motor
Snailor Built
Jun 14, 2010 07:13 PM
KraziCivicSi
Mar 24, 2007 08:01 AM
ej_3
Jul 14, 2004 03:01 PM
EX-T
Dec 2, 2003 03:53 PM
jonoknut
May 7, 2003 05:45 PM
