Question.
Old Oct 11, 2002 | 04:30 PM
RaVAGE00's Avatar
New User
Default Question.
I want to set the timing on my 2000 stock R to 18 degree's... Should I raise or lower the fuel pressure at all when making the timing change? Or does it even matter?
Thanks.
Old Oct 11, 2002 | 06:14 PM
Bbasso's Avatar
Default Re: Question. (RaVAGE00)
I belive you should leave the FPR as is. but could be wrong.
the only thing your going to do is bump the timing to 18, right?
Old Oct 11, 2002 | 07:11 PM
RaVAGE00's Avatar
New User
Default Re: Question. (Bbasso)
yes that is correct. However, I was just wondering if the car will benefit from a step up or step down in fuel pressure as a result of the advanced timing.
Old Oct 11, 2002 | 11:06 PM
JPP's Avatar
JPP
If the car is pretty much stock, a timing of 18 degrees is within spec so the stock fuel pressure should be good.
Old Oct 12, 2002 | 05:01 AM
RaVAGE00's Avatar
New User
Default Re: Question. (JPP)
thanks guys.
lsdc4
Apr 20, 2009 07:55 AM
13secondmonster
Jul 27, 2004 05:06 PM
ITR.#1446
Mar 25, 2004 01:02 PM
nd8ch
Feb 26, 2003 06:40 PM
Cosworth
Jun 3, 2002 03:09 PM
