help ...cam install
Old Feb 11, 2003 | 06:50 PM
dubbb ls's Avatar
Default help ...cam install
hey guys this is my first help but on a scale of 1 to 10 how hard is it to install cams on my ls..
Old Feb 11, 2003 | 07:18 PM
IN VTEC's Avatar
Default Re: help ...cam install (dubbb ls)
I'll give it a very subjective 4.
Old Feb 11, 2003 | 07:26 PM
B18EG6's Avatar
Default Re: help ...cam install (IN VTEC)
only because of the timimg belt which HATED me..other than that...real easy.
Dont overtorque the cam caps, or your cams will bind up.
Dont force the distributor in the wrong way either, that will also make the cams bind.
Use assembly lube too so nothing burns up
Old Feb 11, 2003 | 09:14 PM
cheezthis's Avatar
Default Re: help ...cam install (B18EG6)
As long as your timing belt tensioner bolt isn't being a pain...it's not too tough, just have a helms and a deep socket 14 mm w/you among the standard torque wrench and metric set.
Old Feb 12, 2003 | 09:24 AM
allmotorls95's Avatar
Default Re: help ...cam install (cheezthis)
anybody have the helms for this...i wanna see some pics i can't find mine..
Old Feb 12, 2003 | 09:47 AM
bump
Old Feb 12, 2003 | 10:53 AM
Tweakmeister's Avatar
there are several websites detailing cam installs, including c-speedracing.com
Old Feb 12, 2003 | 11:31 AM
Default Re: help ...cam install (Tweakmeister)
thanks ill tell my friend
hylaxrng
15
Dec 16, 2013 04:54 AM
94b16teg
Aug 11, 2006 09:11 AM
ramz7887
Apr 15, 2003 05:30 PM
ingrate
Dec 9, 2002 09:21 PM
2fknlo
Apr 1, 2002 06:40 AM
