help
Old Apr 30, 2007 | 01:14 PM
jlfrnce's Avatar
Default help
I have a 94 w/ '01 gsr swap and also have a chipped ecu and seems like it hesitates and rev tops out at 3500, any1 have any suggestions, only looking for help not sarcasim
Old Apr 30, 2007 | 01:31 PM
St Jimmy's Avatar
* B A N N E D *
Default Re: help (jlfrnce)
Your ECU is running in safe mode because it cannot recognize the chip. Pretty much whoever did the chipping doesnt know what they are doing...
Old Apr 30, 2007 | 04:42 PM
jlfrnce's Avatar
Default Re: help (St Jimmy)
is there a way to find out for sure? or what i can do to solve this problem? i bought it off http://www.Xenocron.com and when i started it back up it didnt do it at first then when driving get a check engine andthen wont go past 3500rpm
Modified by jlfrnce at 6:02 PM 4/30/2007
Old Apr 30, 2007 | 05:02 PM
doood's Avatar
been there done that
find out what code you're throwing
Old Apr 30, 2007 | 05:15 PM
jlfrnce's Avatar
Default Re: help (doood)
i get a 16 , but the fuel injecyors are the obd2 just grounded off the tab to get plugs to fit
Old May 1, 2007 | 10:57 AM
St Jimmy's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlfrnce &raquo;</TD></TR><TR><TD CLASS="quote">is there a way to find out for sure? or what i can do to solve this problem? i bought it off http://www.Xenocron.com and when i started it back up it didnt do it at first then when driving get a check engine andthen wont go past 3500rpm
Modified by jlfrnce at 6:02 PM 4/30/2007</TD></TR></TABLE>
Go get your ECU rechiped and not by them. They messed it up the first time. If you dont believe me run a unmolested ecu in your car and you will see it runs fine with no cel.
Old May 1, 2007 | 06:05 PM
jlfrnce's Avatar
well i tried the other chip that came with ecu and fired right up. i dont think it rev'd as quick as i think so gonne check timing in daylight. but ya figure they would put the programed chip in there that you are have set to your setup. thanks for the help guys!
JDM Approved
Jul 2, 2008 10:33 PM
98B18C1
Dec 7, 2006 12:02 AM
nvmyb20hatch
Aug 23, 2006 07:44 AM
GTlvr82
12
Jan 15, 2004 08:56 PM
743power
Apr 22, 2003 11:17 AM
