A-arm spec's?
Old May 1, 2007 | 03:30 PM
slowly slipping away's Avatar
Default A-arm spec's?
I have a buddy that just replaced his A-Arms with some new adjustable ones and he is wondering how tight the bolts need to be at the anchor points where it attaches to the chassis. Right now, they are loose enough to where you can move them up and down easily by hand. He states that you can actually tighten them up enough to where they won't move by hand anymore, but wonders if the cars weight would be enough to move them.
Question is: How tight do those bolts need to be in order to be correct? Are there torque specs for those that anyone can post here?
Old May 1, 2007 | 05:32 PM
Sam92Teg's Avatar
Default Re: A-arm spec's? (slowly slipping away)
The anchor bolts that attach the upper A-arms to the shock tower are 47 lb/ft. These are the bolts that go thru the chassis and are tightened in the engine bay.
Old May 1, 2007 | 06:01 PM
Default Re: A-arm spec's? (Sam92Teg)
well, I belive what he was asking me about was the other end of the anchor, where they attach to the A-arm itself..but thanks for the info!
Old May 1, 2007 | 07:01 PM
Sam92Teg's Avatar
My bad, you asked where it attaches to the chassis, that's what thru me off. The other end of the anchor bolts where it goes thru the A-arm requires 22 lb/ft.
D16SohcVtec
Jun 4, 2008 03:52 AM
spoolinegsr
Jun 6, 2007 08:41 PM
Twistedframe
May 2, 2007 11:10 AM
idontcare
Aug 17, 2003 09:09 AM
Madracer1
10
Dec 19, 2002 01:49 PM
