HELP?!?!?!
Old Apr 14, 2007 | 11:27 PM
posHonda's Avatar
Default HELP?!?!?!
ok so i was trying to get the 32mm nut off for the axles but i accidentally took off the brakes first...upon putting the brakes back on i only assembled one side...i tried pushing in the brake but the obvious thing came to me and there was a shitload of pressure on the pedal...the other side i forgot to reassemble was leaking a bunch of brake fluid...so that metal piece thats supposed to push in the brake pads is locked at that spot and i was wondering how do i push it back in to reassemble it?!?!?! i know im a newb at this but im trying to learn
Old Apr 15, 2007 | 07:24 PM
j_bizach's Avatar
Default Re: HELP?!?!?! (iVteC_PoWeR)
By
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iVteC_PoWeR &raquo;</TD></TR><TR><TD CLASS="quote">so that metal piece thats supposed to push in the brake pads is locked at that spot and i was wondering how do i push it back in to reassemble it?!?!?!</TD></TR></TABLE>
Im assuming you mean the piston in the caliper anyway old trick. Find a c clamp and one of the old break pads. Put the brake pad over the piston the put the c clamp on the back of the calipetr and the brake pad thats covering the piston. Then tighten the c clamp untill the piston goes all the way in. Oh and dont forget to pop the top on your brake fluid resovor. work everytime
Old Apr 16, 2007 | 04:42 AM
slomob18b's Avatar
Default Re: HELP?!?!?! (j_bizach)
Yup first thing to do is open your brake fluid cap in the engine bay. You can also try to use vice grips as they worked for me.
Fatcobra
Mar 27, 2007 11:45 AM
nonvtec92
Mar 18, 2007 03:32 PM
Tutin77
Sep 18, 2004 09:42 AM
FastNFurious
Mar 6, 2004 06:08 AM
yaya
May 19, 2003 08:18 PM
