Heater core problem
Old Apr 28, 2009 | 06:45 AM
slimLS's Avatar
Default Heater core problem
I've done a search and just trying to confirm that this is a heater core problem because its a pain in the butt to replace. Both my drivers side and passenger floor is damp, my coolant is usually gone in 3 days and i don't see any leaks. Heater core right? thanks in advance.
Old Apr 28, 2009 | 07:39 AM
twentyhurtz's Avatar
Default Re: Heater core problem
sounds like it to me.... confirm the fluid is green or antifreeze...
Old Apr 28, 2009 | 07:41 AM
if you want to be extra sure! get a male- male radiator hose connector - not sure what size, and temporarily bypass the heater core under the hood, remove the hose from the core and the hose from the heater core valve under the hood and connect the hoses together to loop the fluid, run the car a week or two, if problem has resolved, its definitely a leaking core.
Old Apr 28, 2009 | 07:44 AM
seanbev24's Avatar
Yep sounds like the heater core, not fun at all.
Old Apr 28, 2009 | 05:55 PM
Akavietboy201's Avatar
I think i have to the problem what u had but my coolant was leaking on the passenger side below the dash. Nope not fun at all i had to fix my heater core in the cold for 2 day straights an the temperature was below 40/F dat shiat was pain in the as good luck dude
Old Apr 29, 2009 | 06:05 AM
mage182's Avatar
Make sure that you get some sort of carpet cleaner to clean the carpet in the front while your dash is out. It's best to get all the coolant cleaned up then because it will leave a residue for a long time if you just leave it.
Old Apr 29, 2009 | 06:13 AM
my heater core change, just jumping in there and doing it, took about 12 hours start to finish.. i didn't just hack the clips, i undid each wire anchor and made sure i did not mess anything up, heater core was a 4 seasons, was 90 at o'rileys
Old Apr 29, 2009 | 06:19 AM
Schister66's Avatar
Man U FTW
Wow, do i feel sorry for you. It sounds like you have the problem correctly pinpointed, but that isn't going to be a fun fix. Best of luck to ya
Old Apr 29, 2009 | 09:38 AM
jdm_bones's Avatar
Yup, this is a heatercore problem...check to make sure that it's not just the line that brings in the coolent...sometimes the rubbing of to metal will cause a hole on the weaker metal...hence your aluminum hose rubbing on your firewall...But might just be a bad heater core all together.
andyz
Apr 6, 2022 08:14 PM
mjmonteiro
Mar 23, 2016 10:25 AM
EG9_808
Sep 1, 2008 06:16 PM
carlip
Nov 15, 2005 06:34 AM
al3e
Sep 29, 2003 03:45 PM
