Headlight problem
Old Feb 18, 2004 | 04:59 PM
cincispeedemon's Avatar
Default Headlight problem
Ok, only my drivers side low beam works, but both high beams work. Whats the forking deal?
I replaced both bulbs and it still doesn't work.
when i was playing with them, i found out that it's actually my low beam that is coming on in the passenger side.
Old Feb 18, 2004 | 05:32 PM
krn.racer's Avatar
Default Re: Headlight problem (cincispeedemon)
get it checked!
Old Feb 19, 2004 | 02:07 PM
Default Re: Headlight problem (krn.racer)
I was trying to avoid going to a tech, does anyone know where I could get a picture of the fuse/relay cover, mine was missing when got the car.
Old Feb 19, 2004 | 02:24 PM
nolexforever's Avatar
which side low beam is not working?? you first stated your driver side lowbeam works and then you said you "found out that it's actually my low beam that is coming on in the passenger side"..so i'm bewildered.
if i remember right, the fuse for your lowbeams work for both sides..there might be a break in your wires or maybe its not completely plugged in..if anything else, maybe the bulb is cracked and you dont know it...otherwise, i dont know...
Old Feb 19, 2004 | 03:31 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Headlight problem (nolex7)
There are separate fuses under the dash for each low beam, 10A each. I don't know what position they are in, though.
Old Feb 19, 2004 | 04:46 PM
integraGSR1's Avatar
what year? if it's a 94+ integra, the first is to check you lights to see if they are broke. 9006 for the lowbeams and 9005 for the highbeams. if both are good, check the underdash fuseboxe. then you can also check the fusebox under the hood.
Old Feb 19, 2004 | 06:43 PM
Deluzional's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cincispeedemon &raquo;</TD></TR><TR><TD CLASS="quote">Ok, only my drivers side low beam works, but both high beams work. Whats the forking deal?
I have a similar situation, but mine is on and off. My headlights work but sometimes only one of my high beam comes on. Ill check out the 10A fuses
Old Feb 19, 2004 | 07:12 PM
vain's Avatar
if u have a 94-97 teg .. http://www.team-integra.net/se...D=514
Old Feb 19, 2004 | 08:42 PM
Skinnyjohnmo's Avatar
I kinda had the same problem with my passenger side taillight. It was a bad ground. Where the ground wire connected to the plug was bad.
Old Feb 20, 2004 | 02:16 PM
Sorry, it's a 90 integra.....
civicx
Dec 13, 2016 05:32 AM
JJ's civic
Nov 29, 2008 12:23 PM
JDMtype Eg6
Aug 4, 2005 07:36 PM
EH2_pReStO
Nov 21, 2003 02:28 PM
xevanx
Feb 20, 2002 05:09 PM
