Individual fuzes for headlamps
I was wondering if any of you guys know if the low beams left and right and the high beam left and right on a EG have individual fuses for each??
The reason I am asking is that for some reason mine don't work but the bulbs are fine and the main fuse seems to be fine...
My high beams work for both..and the left low beam works...but the right doesn't...I switch the bulbs around...and still the left low beam doesn't work..
Re: Individual fuzes for headlamps (Mr Milano)
no i switch the bulbs..and no matter what the left low beam didn't work...the same bulb work fine on the other side...so I don't know whats up..
Re: Individual fuzes for headlamps (prestoizm)
Yes both of your headlights and low and high beam have individual fuses, I had a problem where my left low beam didn't work but the high-beam worked fine, then i realized to look at the fuses and sure enough there was a fuse for left-high and low beam and also with right-high and low beam.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prestoizm »</TD></TR><TR><TD CLASS="quote">no i switch the bulbs..and no matter what the left low beam didn't work...the same bulb work fine on the other side...so I don't know whats up.. </TD></TR></TABLE>
Then I suggest you read and edit your original post. There are ind. fuses. Good place to start. If not pull the plugs off the back and inspect them.
Okie so thanks for the info. Now that i know that there are individual fuzes where are they located?? I checked all my fuses prior and they where fine...Are they in a different location??
I dont have a fuse cover that says what fuse is what...=/
GraphiteMW
06-26-2008 04:12 PM
Cashieboi
12
03-01-2008 08:44 PM
