Header install help required
Old Dec 27, 2002 | 12:36 PM
RacerXintegra2k's Avatar
Default Header install help required
ok going to put on a used 4-2-1 dc sports header .. what do i need
this is the list of things i have in mind
exhaust gasket for the top
donut gasket
2 studs, 3 nuts, 3 bolts
also can i reuse the 2 dounut gasets in the middle of the header ? since its a 4-2-1 ?
[Modified by RacerXintegra2k, 5:01 PM 12/27/2002]
Old Dec 27, 2002 | 05:22 PM
neo1z's Avatar
Default Re: Header install help required (RacerXintegra2k)
those would be helpful...when i did mine though i reused all of my stock parts, and everything has worked fine for about a year now.
changing that header gasket would be a good plan though.
Old Dec 28, 2002 | 03:00 AM
slomob18b's Avatar
probably dont need to replace the donut gasket. but maybe the studs, nuts, and bolts that connect to the cat. i hated takin those off its such a b!tch. you have to hold on side with a wrench then screw off the other side with a ratchet or vice versa. good luck on the install man and dont break any bolts
Old Dec 28, 2002 | 03:27 AM
IntEGNYC's Avatar
Default Re: Header install help required (slomob18b)
if you do break any bolts, remember you can always get them at the dealer or online. Good Luck on the install.
Old Dec 28, 2002 | 06:12 AM
JeremyL's Avatar
Default Re: Header install help required (IntEGNYC)
well since i just got my new header on i recommend to you the following, first take off the mounting bracket at the bottom of the stock header right as it hits the b pipe. that will save u a lot of aggrevation when you get everything else off. have handy a good set of metric sockets and 12 point wrenches a breaker bar with some short extenders would help to. get the spring bolts that connect the cat to the b pipe theyll probably break when you take the stock ones off, definitely replace the manifold gasket and if you can actually get the donut gasket off you may be able to reuse it but i would suggest getting a new one since youre already in there, theres also another mounting bracket on the b pipe that imo is useless but to remove it easily remove it from the top where it connects to the subframe rather than where it connects to the b pipe, youll see all of this once youre in there and im sure it sounds greek to you now but youll know once youre in there, knowing the following before i started would have saved me a ton of time but thats how one learns
Old Dec 28, 2002 | 08:03 AM
Default Re: Header install help required (JeremyL)
thanks for all the help guys. do you think i should buy some more bolt and stuff incase they break or is 3 enough ? my car is fairly new with 22k miles
Old Dec 28, 2002 | 10:39 AM
JeremyL's Avatar
the header should come with bolts and the gasket that connect the manifold to the b pipe, with only 22K the bolts probably wont break but just get the bolts that connect the b pipe to the cat cuz it would really suck if you broke them anyway and you couldnt drive you car until you got them and had to stop working to run out and get the bolts and of course it will happen either late at night or on sunday when the dealer isnt even open and then ud be totally screwed, i also suggest getting a new o2 sensor since you probably wont be able to get the old one out of the b pipe. also get some high temp anti seize lube and put some on every bolt and nut that you screw on
Old Dec 28, 2002 | 11:38 AM
ummm the header i got is used .. it has a couple rusted bolts and 2 rings .. oh yea and it has an o2 sensor on it already .. but it used to be on a 94 LS now it will go on a 2000 LS ... ummm will teh diff ecu's be a problem ? with the o2 sensor ?
Old Dec 28, 2002 | 11:59 AM
94TealGSR's Avatar
Use your o2 sensor. A) it's newer and B) I'm pretty sure the sensors are diff between obd1 and obd2.. but not positive. Either way, just use yours.
Project_EK
Sep 14, 2005 02:26 PM
ERIC!
Aug 13, 2005 05:11 PM
aznchino16
Dec 12, 2002 09:20 PM
ScottEK
Aug 25, 2002 02:53 PM
ToneyTigre
Nov 21, 2001 11:26 AM
