GSR's with test pipe help!
Old 08-16-2001, 02:10 PM
New User
1fastGSR's Avatar
Default GSR's with test pipe help!
I need some help! Would the check engine light come on with a test pipe? even if it has bung for the O2 sensor? how do you turn it off?
If heard of people say that there is NO gains with a test pipe?? Is that true? If not, what kinda of HP gains am I looking to get? Thanks
Old 08-16-2001, 02:57 PM
Rainmaker's Avatar
Default Re: GSR's with test pipe help! (1fastGSR)
Test pipe does not produce any significant gains for a car with mild bolt-ons. THe light that comes on is leeting you know that you have increased your level of pollution by about 1000 times.
Rainmaker, friendly Honda-Tech environmental consultant
Old 08-16-2001, 03:11 PM
New User
1fastGSR's Avatar
Default Re: GSR's with test pipe help! (Rainmaker)
I bet my car with no cat makes less pollution than those big *** trucks and SUV with 2 cats!!!!!!!!!
Old 08-16-2001, 03:21 PM
Rainmaker's Avatar
An SUV can pollute up to (rough estimate) 5 times more than a car with a cat. That still means you without cat = 200 SUVs.
Rainmaker
Old 08-16-2001, 03:38 PM
New User
1fastGSR's Avatar
I'll just wont cut the grass anymore to make up for it!
Old 08-16-2001, 04:31 PM
New User
BlowOff's Avatar
Don't forget to not trim the shrubs too!!
Old 08-16-2001, 04:37 PM
New User
kikkoboyie's Avatar
Default Re: GSR's with test pipe help! (BlowOff)
damnit... there's been so many posts on testpipes... whats the bottom line?
its a cheap mod that provides decent gains or what?
someone set it straight.... so i can get one
Old 08-16-2001, 04:41 PM
New User
1fastGSR's Avatar
Default Re: GSR's with test pipe help! (kikkoboyie)
that's the whole reason I started this topic!!! I can NOT get a straight answer. I wish someone would post a dyno!!!!! somepeople say it makes NO HP, other people say it makes 8-10 HP. I'd be happy with 5-6 HP!!
Old 08-16-2001, 05:03 PM
randomwalk101's Avatar
The cat is a restrictive area of your exhaust. Openning this up should allow more exhaust flow, increase hp and keep your engine cooler a little bit in the process. You will get greater gain if your vechicle if force induced, taking into account that the rest of your exhaust is not restrictive.
Old 08-16-2001, 05:21 PM
New User
slowerthanu's Avatar
Default Re: GSR's with test pipe help! (randomwalk101)
Next tuesday I am having a Mandrel bent exhaust using a resonator and a Magnaflow muffler. The shop want's to build me a test pipe for TRACK use only.
Since the ECU JUN is building for my car will take away the OBD 2 signals I figure it will be ok, but for now is there anyway to keep the dreaded CEL away with my current OBD 2 setup.
Old 08-16-2001, 05:31 PM
SMSP's Avatar
I had a 99 Expedition with the 5.4L it got around 15 mpg around town and 18 on the highway (2WD). It was classified as a LEV and had 4 cats, 2 for each bank. My wife drives a 98 Volvo S70 GLT that gets only 21 mpg in town and about 28 mph on the highway. Well the Volvo's emission numbers were about 3 times that of my Expedition but was only getting (21/15) 40% better fuel mileage around town which was about 80% of its duty. So, even though my SUV was getting worse mileage is was polluting less than the Volvo.
Old 08-20-2001, 11:13 AM
New User
kikkoboyie's Avatar
Default Re: GSR's with test pipe help! (SMSP)
aite so......
w/ forced induction, ur gonna get really good gains with a test pipe
but w/ mild bolt ons, ur gonna get.....
Old 08-20-2001, 12:43 PM
New User
sikgsr1's Avatar
Why dont you take that money and go buy a BBK or JG throttle body and intake manifold.......Test pipes are a waste of money on Mild motor setups. You will get way more gain out of those 2 bolt ons.
Mike
Old 08-20-2001, 01:19 PM
PureTeg420's Avatar
Default Re: GSR's with test pipe help! (sikgsr1)
It's funny all these people that bash test pipes when they don't even have them. Have u guys ever actually looked inside your cats? There's so much wire in there it's a joke. When I took my Cat off and replaced it with a 2.5" testpipe I wasn't turbocharged, but I still felt some power gain. Not anything like 10hp, maybe 4 if I was lucky. But after the turbo....damn. If your obd1 just spend 50 on a damn testpipe, your not gonna be dissapointed. And make sure to hold onto your cat..for when u have to pass emissions.
Old 08-21-2001, 03:50 PM
New User
kikkoboyie's Avatar
Mike
bbk or jg throttle body is like a billion tyms more cash than a test pipe.... but if i had the money... i would def get that....
"If your obd1 just spend 50 on a damn testpipe,"
im obdII.... u think i should get one?
98h22a4
01-23-2005 10:21 AM
H23A1LUDE
06-05-2003 08:17 AM
LSVTEC408
06-21-2002 10:51 PM
LillDragun
04-09-2002 02:55 PM
BeanRacer
12-18-2001 06:02 AM
Quick Reply: GSR's with test pipe help!
