GSR dizzy problems, help!
Old Nov 27, 2006 | 08:33 AM
Azn Kenny's Avatar
Default GSR dizzy problems, help!
Car is a 95 hatch with 98 GSR in it converted to OBDI. Last week the dizzy started squealing real bad so I figured the bearing was bad so I borrowed a friend's OBDI dizzy and replaced it, it ran like crap so I checked the timing and with the dizzy all the way advanced (rotated toward the firewall) and I'm only getting 4 degrees of timing, cam timing was not messed with at all.
I've heard about ppl having to swap internals in a dizzy, how does that work? Any suggestions? Thanks.
Update: Tried on TWO dizzys and also used TWO different timing guns on there and same problem! Won't let me advance it past 4 degrees of timing!!!
Old Nov 27, 2006 | 10:16 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Re: GSR dizzy problems, help! (Azn Kenny)
booo, dizzy problems are the worst. i have one right now myself. if u want to swap internals such as the ICM or the coil, def get a haynes manual. itll show u everything.
Old Nov 28, 2006 | 11:33 AM
Azn Kenny's Avatar
Checking the crank pulley today to see if it jumped a tooth there...
Old Nov 28, 2006 | 03:39 PM
JasonST's Avatar
Default Re: (Azn Kenny)
Swapping the internals are really easy. Just take em out and put the other one in, they only go in one way and only fit one way so it's pretty easy, things to swap would be the coil and the ignitor, and if u want u could try buying a new cap/rotor cause they're pretty cheap.
Old Nov 28, 2006 | 06:51 PM
S2KILLA's Avatar
Default Re: (JasonST)
yeah they are but there expensive. buy the manual, test to see wats wrong, buy the proper parts. do it right the first time
MikeD21
Jun 1, 2014 10:11 PM
crappyshifting
Jul 18, 2013 09:00 PM
lilo_goki
Sep 27, 2009 02:46 PM
Azn Kenny
Nov 28, 2006 11:34 AM
SLO Sol
May 8, 2006 05:41 AM
